Leisure and Vehicle Battery Charging by SP
Discussion in 'Solar Power' started by Dorset Diver, Mar 10, 2016.
  1. Dorset Diver
    Dorset Diver Funster
    Dec 23, 2014
    477
    245
    Somerset
    Carthago Chic C-Line with 2 x leisure batteries and a single vehicle battery. 140w SP fitted by Southdowns. I expected all the batteries to be charged by the SP but at present, on this nice sunny day my leisure batteries are showing 13.0v and the vehicle battery is sitting at 12.7v. I suspect that it is not being charged by the SP. Please ask if you need more info to assist.
  2. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    6,976
    13,435
    East Sussex
    I'm not a solar expert, though I also have solar panels in my Carthago Chic, though mine were fitted by Vanbitz
    The voltages you mention seem right to me
    The solar charges the leisure batteries and the engine battery will take a small charge from the leisure batteries if the voltage drops too low, they are not connected otherwise
    In the UK the charge from the solar is still not great as its only March and the sun is still low in the sky
  3. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    7,201
    7,069
    West Sussex
    Depends if the dealer has fitted a dual output regulator or solar split charge relay, if not the engine battery won't charge. If they have fitted either, the engine battery still won't charge until the leisure batteries are up to about 13.6 volts with a split charge rear or maybe more with a dual output regulator depending how it has been set up.
  4. Dorset Diver
    Dec 23, 2014
    477
    245
    Somerset
    The fitted unit is as the photo attached if that is of any help. P1010339.JPG
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,385
    18,074
    YO11 2BD
    Thats a standard charge controller feeding your leisure batteries only unless there been a stand alone split charge relay fitted somewhere.
    If its charging both then the battery voltages should be about the same with the sun shining.
    The meter will show the solar panel output at each battery, not the actual battery voltage, which can only be read when the panel isnt charging....ie: at night etc.
  6. vin0114
    vin0114 Funster
    Feb 8, 2014
    797
    800
    Sheffield
    I think Vanbitz also fit a Battery Master when fitting their panels. I fitted one to my solar system to allow the engine battery to be charged when low from the leisure batteries. The only criticism I have of the BM is that it does not allow charge to the engine battery until the battery voltage falls to around 11.6 volts.
  7. Dorset Diver
    Dec 23, 2014
    477
    245
    Somerset
    I have since discovered that both my leisure and vehicle batteries are charged by the system. Leisure batteries first I think then the vehicle when certain parameters are met. In any event it all seem to work well.
  8. denisejoe
    denisejoe Funster Life Member
    Aug 6, 2014
    1,496
    1,031
    Isle of Sheppy
    My solar is direct to my leasure batteries but through the vans electricky also charges the engine batterybut not until the leasure batt are at about 13.6
    Joe
  9. DBK
    DBK Funster
    Jan 9, 2013
    9,209
    12,821
    Plympton, Devon
    I have an identical controller and it keeps my leisure batteries at 13.8 volts. I can only suggest turn a few things on in the evening for an hour or so, just to drain the battery a bit then check the voltage first thing the next day (it should have recovered a bit from the voltage shown the previous evening) note what the voltage is, then look again at the end of the day. If the panels are working it should show an increase but I don't see why it isn't showing more today. Something isn't right.
    Do you not have a meter which shows the amps going into or out of the leisure battery? Without one you will always struggle I think to know what is happening.
  10. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,875
    6,007
    Guisborough
    Some vans have the likes of CBE CSB2 fitted as standard and they need something like 13.8 volts at the leisure batteries before kicking in to charge to the vehicle battery.
    Martin
  11. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,631
    2,813
    Surrey
    I had the exact same setup fitted by Eddie, the Battery Master should start charging the cab battery when the difference is more than 0.5 volts (from memory). Mine certainly seems to maintain the cab battery topped up when there is reasonable daylight.
