leirure battery (1 Viewer)
jandee
15
4
Just bought first motorhome and the leisure battery is losing charge after only using overnight for lights, water pump and heater, it is a new battery and we fully charged it before we set off, does anyone have any ideas what the problem might be please?
J
jandee
15
4
The charge went down to about 60% then we couldn't turn anything on
839
2,102
Nr Hastings, East Sussex
AutoTrail Tracker RL
since 2010
Jandee,
I think we need to start looking at numbers!
What is the capacity of your leisure battery?
How many lights did you have on, what is their wattage and how long were they on?
What sort of heater were you running - make/model? Presumably you were using gas to fuel the heating and the electricity was for blowing the air?
Were you running a TV? If so, for how long?
Was anything else electrical being used? If so, what?
Batteries only have a finite capacity....
Bill
DanielFord
3,020
3,086
That is a lot. We have overnighted many times using the appliances you describe, also a 12 volt television for a good few hours in the evening, and we don't use anything like that.
So next question, what is the power rating of the battery? (it will be a number followed by ah, amp hours)
And bill beat me to it :)
J
jandee
15
4
It was working ok at lunchtime, then we only used the water pump, when we came back to the van nothing would work. The night before we had 3 lights on for 2hrs the water pump and the controls for the water heater which we did leave on all night as this is gas fired it should not be a problem.
43,304
49,293
Agreed to a point.
the heater control circuit will only use a small amount of power.....but the blower fan will use a lot.
Overnight it could be as much as 50amps.
Opps...just noticed you said WATER heater....i read it as heater.
How did you confirm the battery was fully charged and how was it charged.
J
jandee
15
4
Hi papa John, the battery was charged overnight with a battery charger and it showed fully charged when I installed it in the van
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
If it is NEW why was it charged overnight? New batteries are supplied fully charged.
J
jandee
15
4
It was new in January but the van wasn't used for weeks as we where both ill and with the cold weather the battery lost some of its charge
Techno
Jul 28, 2010
15,475
20,756
May 2010
I'm picturing that it has been left in winter months in freezing cold to discharge itself which may have reduced its capacity.
J
jandee
15
4
I agree, but once you recharge it it should be ok, or has it damaged it permanent
Techno
Jul 28, 2010
15,475
20,756
May 2010
It depends how severely discharged it was but as you can't get one night out of it I can only conclude that it has suffered damage.
DanielFord
3,020
3,086
We still need to know that amp hour rating, if too low then this usage would indeed discharge the battery.
J
jandee
15
4
I will take it to where I bought it ask them to give it a test, they are very good and have been very helpful in the past. Thanks for your help techno
43,304
49,293
All lead/acid batteries have a self discharge rate and could be flat in a matter of weeks.
If it has been left in a discharged state for several weeks it will be badly sulphated and will not hold a charge......and very doubtful it will recover at all.
all wet batteries must be stored fully charged to prevent damage to the plates.
