LEDs
Discussion in 'Motorhome Chat' started by gazzeroo, Oct 13, 2014.
  1. gazzeroo
    gazzeroo Funster
    Sep 14, 2014
    63
    5
    Norwich
    Sorry if this is a stupid question, but I just read a forum about changing the lighting to LED`s. Does this mean that even when on an ehu the voltage to the lights is still 12v, cos I`m sure that 12v leds will not work thru 240v without a special transformer
  2. SandJ
    SandJ Funster
    Sep 14, 2007
    1,614
    560
    North Yorks
    You are running your lights via 12v not 240 is the simplest explanation. 240 is only used for 240 items
  3. Mattyjwr
    Mattyjwr Funster Life Member
    Aug 18, 2013
    1,945
    3,454
    Beds
    Your EHU will power your 12v battery charger and your 240v sockets. Your lights will run on 12v from your (leisure) battery. We swapped our 12v tungsten bulbs for 12v warm white bulbs and understand that the saving is 90% of what we would have used previously. IMHO, avoid bright white bulbs - they are too stark and white and tend to wake people up during the evening making sleep difficult.
  4. PP Bear
    PP Bear Funster Life Member
    Apr 5, 2013
    2,479
    7,687
    UK
    Even on EHU most of your systems will be running on 12v :)
    There'll be a number of systems that only work on EHU that aren't 12v. Namely the microwave (unless you have a rare 12v one, but most have 230v in their motorhomes), the fridge when you select 230v supply, the 3 pin sockets, the electric element in the water heater to name a few :)
    Depending on what you have fitted in the motorhome in the way of an inverter if any, you'll mostly run the 12v system, hence the need to have good leisure batteries and possibly a solar panel to keep them topped up when away from EHU for any length of time :)
    There'll be lots of Funsters along to give some advice I'm sure, but I monitor my leisure batteries to ensure they have plenty of charge for their task ahead and also have a solar panel to keep them charged whenever possible :)
    • Like it Like it x 1
  5. Mel
    Mel Funster
    Oct 6, 2012
    2,152
    2,182
    De Haan Belgium
    IMO No question on motorhome fun is stupid.
    Every question will help someone to understand there motorhome beter.
    Mel
    • Like it Like it x 6
  6. Gorse Hill
    Gorse Hill Funster
    Feb 2, 2013
    1,977
    1,792
    Stretford
    Assuming you have 12v fittings, highly unlikely you will have 240v ac light fittings but you never know who had the M/H before you and if they did any alterations as I say very unlikely but check the bulbs currently installed and check there voltage (should be on the bulb) if 12v led will work ok however try and buy from a reputable dealer as some LEDs don't like more than 12v and can overheat so look for ones rated between 12/14 v
  7. Gorse Hill
    Gorse Hill Funster
    Feb 2, 2013
    1,977
    1,792
    Stretford
  8. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    3,039
    2,816
    Englishman in Mid Wales
    Good, why has my motorhome got four wheels?:whistle::confused:
  9. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    3,039
    2,816
    Actualy my Auto-sleeper Pescara had one light fitting in the middle of the motorhome that was 240 so just be aware(y)
  10. golly
    golly Funster
    Aug 16, 2009
    1,238
    2,179
    Co Durham
    Does it ? mine only has three :D
    [​IMG]
    • Like it Like it x 3
  11. Forester
    Forester Funster
    May 21, 2012
    159
    175
    forest of dean
    What about the steering one?
    or has it got handlebars?
  12. Mel
    Mel Funster
    Oct 6, 2012
    2,152
    2,182
    De Haan Belgium
    It would be too heavy with six.
    Mel
  13. Gorse Hill
    Gorse Hill Funster
    Feb 2, 2013
    1,977
    1,792
    Stretford
    I had a caravan that had a couple of 240v light fittings as well, think a lot of the newer vans are 12v but that's why I said check to just be on the safe side as the OP didn't say how old the van was
  14. gazzeroo
    gazzeroo Funster
    Sep 14, 2014
    63
    5
    Norwich
    Once again thanks for all the advice, you lot are most useful with a sense of humour on top
    regsrds
    Gary
  15. SUGGY
    SUGGY Funster Life Member
    Nov 23, 2011
    971
    1,699
    scunthorpe
  16. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    4,013
    9,221
    NW England
    Some of my LEDs fitted about 4-5 years ago have begun to flicker so they don't last forever.
    If you're converting from halogen to LED it's not always straightforward, as LEDs have a different shape and the light fitting may not have been originally designed to accommodate them. I had to rotate and re-glue the sockets for the two pins on some of my light fittings before they'd take LEDs. If you don't want fluorescent tubes in your MH any more you'll need to buy a completely new light fittings for LEDs.
  17. gazzeroo
    gazzeroo Funster
    Sep 14, 2014
    63
    5
    Norwich
    By the way does the reference OP, Gorse hill made, stand for old prat? :)
  18. gozomike
    gozomike Funster Life Member Life Member
    Mar 16, 2010
    887
    667
    Warwickshire - sometimes - but not often
    I see you say STILL in your post.
    It will not change if the EHU is on, the volts to the bulbs will be constant. As stated by others this is normally 12v.
    OP = Original Post:)
  19. voyagerstan
    voyagerstan Read Only Funster
    Aug 7, 2011
    323
    211
    torquay sometimes
    :moon2: ner ner na ner i've got six wheels so there :whistle2::whistle2:STAN
