LEDs getting hot..?
Discussion in 'Tech/Mech General' started by Smith and Sharp, Apr 19, 2016.
  1. Smith and Sharp
    Smith and Sharp Funster
    May 31, 2015
    1,743
    2,693
    Cornwall
    Just noticed that my G4 replacements are hot in my downlighting spots, am I right in thinking that they should burn cool...?
    These are what I've used....
  2. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,218
    14,193
    Bolsover, Derbyshire
    the details don't quote the wattage, presuming they are 5W ish there will still be some heat, but I would not have thought they would be hot, certainly nowhere near as hot as the halogens they replaced
    • Like it Like it x 2
  3. Gromett
    Gromett Funster
    Feb 27, 2011
    8,256
    15,375
    UK
    The bulbs tend to be specced at 12V. Mine all got hot and failed early due to being on hookup quite a bit. The charger voltage quite often hit 14.5V.
    I put a voltage regulator on my lighting circuit to stabilise the voltage at 12v and I don't see the overheating problem anymore and the LED's last a much longer time.
    • Like it Like it x 1
    • Useful Useful x 1
    • Informative Informative x 1
  4. Smith and Sharp
    May 31, 2015
    1,743
    2,693
    Cornwall
    I think they are 1.5 or 3w?
  5. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,218
    14,193
    should be even cooler then
    worth looking at the spec, some have specific input voltage, as Gromett had suggested this could be an issue, you can get some that work within a wider range say 10 - 36V DC something like that
    they could just be a bad batch though, or not a good make
    the first batch I bought caused me all sorts of issues with fuses, one bulb even smoked when fitted, new ones from a new supplier all fine (y)
    • Thanks Thanks x 1
  6. Badknee
    Badknee Funster
    Aug 25, 2014
    3,840
    17,230
    notloB
    After taking advice re 12v LED's being a bit iffy I went for these. Warm in the lounge area and cool in the kitchen and bathroom and they have been great.
  7. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,218
    14,193
    or 8 - 30V DC for instance (y)(y)
    • Thanks Thanks x 1
  8. scotjimland
    Jul 25, 2007
    28,993
    25,691
    Suffolk
    buy cheap you get cheap..
    as already said.. you need LEDs that are voltage regulated from 10 - 30v as sold by Aten lighting
    Regulated from 10-30V
    Diameter - 30mm
    Approximate light output - 160lm
    1.6W power consumption
    Not polarity Sensitive
    1 year guarantee
    • Like it Like it x 3
  9. Masman
    Masman Funster
    Sep 25, 2009
    324
    207
    south yorkshire
    I had same problems.Bought of eBay.Mine got so hot they started smoking.so hot it took the skin off fingers just touching.Stripped them all out.Bought from Aten lighting two year's ago.no problems all cool.The old saying you pay for what you get.Some on here have bought from eBay with no problems.
    • Thanks Thanks x 1
  10. Gromett
    Gromett Funster
    Feb 27, 2011
    8,256
    15,375
    UK
    There are 3 ways to go about this.
    1) Buy unregulated LED's dirt cheap and connect them to your (unregulated) battery directly. Live with heat problems and much shorter lifespan.
    2) Buy regulated LED's, These come with a regulator/voltage converter built in. These are a bit pricier but will run the LED's at a precise voltage optimised for lifespan.
    3) Buy a regulator and connect it to the supply for all Lights, then use cheap unregulated LEDS.
    The 1st option is cheap up front but will cost you in the long run.
    The 2nd option is best if you can't install a fixed regulator. However it will cost you a little more up front and has medium term cost impacts.
    The 3rd option is best if you can install a fixed regulator. It costs quite a bit up front but your long term costs are reduced.
    If you are a fulltimer or spend a lot of time in the van then the 3rd option is best. If you are just a summer user for weekends and the odd week then option 2 will probably be best.
    I have been through all three options and the final one was the best one for me as a fulltimer. The individual regulated LED's did last a lot longer than the cheap ones but they still went dim (in groups of 3) after 3-6 months of non stop use...
    I was going to give the link to the regulator I bought but the companies website is currently down for a rejig.
    • Informative Informative x 2
