led strip lights
Discussion in 'Motorhome Chat' started by camocam1, Feb 16, 2014.
  1. camocam1
    camocam1 Read Only Funster
    Aug 28, 2012
    1,112
    783
    Elgin,Moray,Scotland
    The boss wants led strip lights fitted above the lockers and looking on flea bay it seems you can but the self adhesive strip a connector and a 240v / 12v charger for them but that means having to use a 240v socket !!!
    Not being too technical but can I split a 12v feed to the spot lights below the lockers and connect to that with an on off switch of some kind ??
  2. hilldweller
    Dec 5, 2008
    26,871
    25,734
    Macclesfield
    They work direct off the leisure battery.
  3. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,046
    3,448
    walthamstow east london
    yes just ditch the 240 to 12v part and wire them to existing 12v supply via a switch and idealy a fuse, only thing to watch is they only work if the polarity is correct so not lights reverse the wires
    in a perfect world you would have a voltage regulator to provide a constant 12v but the strips are so cheap to replace anytime its probably not worth the hassle
  4. camocam1
    Aug 28, 2012
    1,112
    783
    I assume the wiring would be source then fuse then switch then lights
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,698
    17,313
    YO11 2BD
    if taking power from an existing source (lights) then no real need for a fuse
  6. Gromett
    Gromett Funster
    Feb 27, 2011
    7,998
    14,297
    UK
    I use them from this guy.
    http://www.ebay.co.uk/itm/271078701124
    The 5050's are the bright ones..
    A quick note though. If you connect them directly to the battery then you will expose them to up to 14.5 volts. They will work fine but it does dramatically reduce their working life.
    I was forever replacing mine due to this until I fitted a 12V regulator to the lighting circuit.
    I used this one.
    http://www.ebay.co.uk/itm/250914348006
    Since then I haven't had to replace the led strips in over a year. Prior to this they were lasting months before fading, flickering or going out (in groups of three leds)
    I am a fulltimer so mine get a lot of hammer especially during the winter.
    • Like Like x 2
  7. Gromett
    Gromett Funster
    Feb 27, 2011
    7,998
    14,297
    UK
    I meant to say if you want the warm ones
    www.ebay.co.uk/itm/281018255808
    I don't like them as they look dim to me. I want the cool white full brightness ones..
Similar Threads
  1. plumber54
    4
    223
  2. Lynne Steele
    17
    852
  3. Swiftroy1
    369
  4. haddy
    12
    868
  5. jaygee
    16
    1,022
