LED Replacement. (1 Viewer)
Crwydryn
113
57
Mid Wales
Compass 300
Newbie
I'm looking to replace the fluorescent bulbs with led in the camper.
The units i have are these.
Link Removed
Link Removed
I managed to get hold of 2x these G23 13W 5050SMD 52LED 110V/220V
Link Removed
Can someone suggest how i can get these to work?
I've measured 240v on the input to the bulb in the camper but the LED doesn't light up.
I connected 240v house straight on to the LED and lights up ok.
Do i need to get a 12v inverter to get it to work?
Many thanks.
GJH
29,450
38,827
None, now sold
2006 to 2022
First of all are you sure that the lighting unit is a mains one? It looks suspiciously like the 12v fluorescent fittings I converted to LED in our previous van.
I still have one of the tubes (GE brand) with reference F 9 BX/840/4P on it. If yours is the same then you need a LED which works on 12v, not 230V.
The conversion procedure is to clip the wires to remove the ballast from the circuit (remembering to clip on the correct side of the switch) and then wire in the LED bulb.
TheBig1
17,591
43,006
The light your trying to convert is a 12v I believe from looking at it. The circuit board being a very low wattage inverter basically which supplies 220v to fire the tube up then a lower voltage to keep it lit. Both being at a very low current. Therefore, the circuit board is not powerful enough to power the new LED bulb.
You either need to fit a suitable inverter board or rewire the light to take 12v LEDs, It may well be cheaper to just replace the light fitting.
43,295
49,268
extremely unlikely its a 12v LED....the op has connected it directly to 230v and it lit up......if it was 12v it would have exploded.
chances are the fluorescent inverter will have an inbuilt choke and starter isn't suitable for led lighting and will need a different inverter...for each light.
Crwydryn
Crwydryn
113
57
Mid Wales
Compass 300
Newbie
I thought it was mains when i measured 240v at the input to the bulb but i'm confused,i thought that the small circuit board was a small inverter but it seems i'm wrong and it's only a ballast,
The fitting is one of these.http://tinyurl.com/827mqmb
This says it's 12v unit and i have 220 led units.
As you say i need to get 12v Led replacement,or is it possible to put a small 50 watt inverter pc board inside?
Something like this.
Link Removed
43,295
49,268
better off removing the ballast and tube and fitting a couple of these in each light case.
Link Removed
from...
Link Removed
Crwydryn
Crwydryn
113
57
Mid Wales
Compass 300
Newbie
:thumb: That explains why i was measuring 240v brill.
So as you say it's best to get an extra inverter or re wire to 12v.
I can use the 220 led in the house ::bigsmile:
Thanks for your help.:thumb:
Crwydryn
Crwydryn
113
57
Mid Wales
Compass 300
Newbie
Link Removed
from...
Link Removed
:thumb: Thanks i will look in to that.
I'll take one of the lights with me to work and see if i can get it to work off 12v first,failing that i will go for the above.::bigsmile:
43,295
49,268
I removed 9 of the twin 11w fluorescent tubes, snipped the inverter 12v feed wires and connected just one strip in each light unit.
each one gives 24w of light but I bought the cool white (too 'blue')...warm white would be better.
eventually i will replace all the other 'missing' strips, effectively making all 9 lights 48w each.
with all the lights (11 in total) turned on a had a 26amp battery drain......I can now run all 9 lights for less battery drain than one of the old 11w x 2 fluorescent lights
Crwydryn
Crwydryn
113
57
Mid Wales
Compass 300
Newbie
:Eeek: My god 11 twin lights,what do you have a double decker bus.:roflmto:
Warm white sounds good.:thumb:
43,295
49,268
it doesnt end there......
along with the roof fluorescents there are....
2 x overhead lights,
one above the dinette (4 x 21w indicator bulbs)
one above the couch (2 x 21w indicator bulbs)...
2 of twin 21w indicator bulb wall lights in the lounge area
2 of twin 21w indicator bulb wall lights in the bedroom
??w over cooker strip light built into the bottom of the microwave.
21w wardrobe light.
i have a 440ah battery bank but it wont last long with that lot burning. :cry:
thats one problem with american RV's....too power hungry, around 450watts in total, or 37.5amps, as they were before the LED strips :Eeek:
Crwydryn
Crwydryn
113
57
Mid Wales
Compass 300
Newbie
21w wardrobe light.
That's a lot of juice :whatthe:
This guy seems to have solved it ::bigsmile:
I tripled my solar generating capacity from 204 to 589 watts...which, as it turns out, is almost enough!
http://www.andybaird.com/travels/life05/catching-up.htm
Crwydryn
Crwydryn
113
57
Mid Wales
Compass 300
Newbie
Link Removed
Link Removed
Link Removed
Many thanks.
Light sorted :thumb:
Fitted one of these-
LM2577 DC-DC Boost Step up Adjustable Power Module
  • Input Voltage: DC 3-34V
  • Output Voltage: DC 4-35V (continuously adjustable)
  • Input Current: 3A (max.)
  • Link Removed
Broken Link Removed
The Led requires 30v DC to light up,connected this up from the 12v supply and light works ok.
Link Removed
Also fitted this to replace the T5 Fluorescent.
Link Removed
hdvrod
859
733
devon
coachbuilt
since jan 2011
Can you give me a link to the bottom tube? thanks:Smile:
hdvrod
859
733
devon
coachbuilt
since jan 2011
Bump!
