led lights
Discussion in 'Motorhome Chat' started by stuboy7, Oct 23, 2009.
  1. stuboy7
    stuboy7 Read Only Funster
    Jul 1, 2009
    42
    folkestone kent
    hi to all, been driving a brand new truck this week in belguim. it had led lights in cab they were brill, can i get same for my swift royale? are they expensive and where to get them from.:thumb:
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,336
    5,347
    East Sussex 01-580-881288
    They are iot cheap and there are different types, suggest you give Darren a ring as he knows more about them than me.
    Peter
  3. stuboy7
    Jul 1, 2009
    42
    folkestone kent
    thanks peter didnt think they would be cheap because they made cab like daylight in the dark
  4. hilldweller
    Dec 5, 2008
    27,213
    26,204
    Macclesfield
  5. stuboy7
    Jul 1, 2009
    42
    folkestone kent
    led
    thanks brian will have a look at site.:thumb:
  6. MicknPat
    MicknPat Funster
    Dec 16, 2007
    629
    2,996
    Touring UK
    stuboy,
    When changing conventional bulbs to LED ones I find the biggest problem is identifying which led replaces which bulb.
    I have managed to change a large number in our American RV but I have two spot lights each side of the cockpit that have 12v screw in type bulbs which I have no idea if a LED equivalent is available.:Sad:
    Mick
  7. hilldweller
    Dec 5, 2008
    27,213
    26,204
    Macclesfield
    Not the cheapest but seem good quality.
    The main choice for you and others is Warm White / Bright White. I tried the bright white and found it too glaring for reading so swapped to warm white which is closer to the colour of incandescent bulbs. I used the bright ones for the kitchen.
    So I guess it pays to buy a couple to start with.
    Whatever the light, the power saving is spectacular as should be the life.
  8. Landy lover
    Landy lover Funster
    Jul 11, 2009
    2,049
    4,215
    Zummerzet
    When we were at Lincoln we changed 6 of our and found them to be so much better - the chap we bought them from had a whole selection of plug in and screw in bulbs and adapters to fit most sorts so they should be available. All he did was LEDs cannot remember his name but he apparently goes to all shows
  9. lebesset
    lebesset Read Only Funster
    May 31, 2009
    760
    like many motorhomers I have had my attention caught by led's for 2 reasons
    improved lighting
    reduced power consumption
    concensus of opinion seems to be that warm white is the best for reading lights , not sure about ceiling lights but maybe brilliant white ?
    HOWEVER it is more complicated than that ! eg I have sideways fitting G4's in my reading lights , so far , so good
    now I presume that 1 led gives out a pretty standard amount of light ...but the question is how many led's should I go for ? .....in the size I want I have seen between 1 and 14 fitted ...how many would for a light which is about 2 ft above my head ...who has fitted led and what strength proved suitable for this height ?
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,936
    17,594
    YO11 2BD
    all mine are G4 side fitting.
    i replaced all the ceiling lights with 9 led 25w equivelent and the under cupboard ones with 6 led 20w equivelent.
    all surface mount diodes...not the miniture bulb type.
    i prefer a light to be just that.....light !....so opted for bright/brilliant white throughout.
    only ones i didnt replace were the overcab bed end lights and the under cupboard strip light over the cooker/sink. dont get used enough to warrent replacing.
  11. lebesset
    May 31, 2009
    760
    tks pj , so thaat's the width you used ...what about the quality ?
    in other words , did that improve the lighting ?
  12. pappajohn
    Aug 26, 2007
    29,936
    17,594
    YO11 2BD
    certainly did. they appear much better.
    i didnt replace the overcab bedend ones or the undercupboard strip over the sink/cooker as they dont get much use so couldnt warrent the cost.
    the originals were 10w halogens 13 of 'em
    replaced with 9 X 25w equivilent in the ceiling (inc 2 in the toilet) and 4 X 20w equivilent in the under cupboard lounge lights.
    my main concern was battery usage.
    13 halogens at 10w each = 130w or just over 10amps
    13 LEDS at 2w each =26w or just over 2amps
    makes one hell of a difference when not on hookup.
    [​IMG]
    got mine HERE
