led lighting in motorhomes
Discussion in 'Tech/Mech General' started by gwyntaxi, Jul 28, 2009.
  1. gwyntaxi
    gwyntaxi Funster
    Jun 9, 2009
    170
    63
    waunarlwydd,swansea
    i have posted 2 previous requests for advice, information, tips, etc. but had NO response so far am i doing something wrong, iam a fairly recent member to
    motorhomefun and even more of a novice to using a computer and this forum:Sad:
  2. peterandbetty
    peterandbetty Read Only Funster
    Oct 5, 2007
    206
    North Staffs
    Hi, We changed all our lights for led lights and its made a bid difference .I got them from e-bay and they came from China and they were very helpful when i needed 5 more lights and they were sold single our in 10's they sold me 5 at half the price of the 10 instead of the single on's that worked out more expensive .It is a lot of money but worth the layout .Hope this helps. Betty
  3. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,742
    8,637
    Tropical Bar,Benidorm.
    Hi gwyntaxi
    We have changed our halogen spot light bulbs for LED's. We chose the Warm White in preference to the Bright White, which we found a bit to harsh. We were unable to find replacements for our flourescent ceiling fittings, but found an LED Strip which fitted our washroom fitting. I am now on the lookout for replacement LED's to fit our awning light. All in all we are very pleased with the LED's, no significant change in the level of lighting but much less drain on the leisure batteries.:thumb::thumb::thumb:
  4. Spacerunner
    Spacerunner Read Only Funster
    Apr 7, 2008
    609
    195
    Hampshire
    I have fitted an awning LED light :Smile:
    Its nine LED's on a card. There is a short length of twin flex which is connected to a standard bayonet fitting base.
    Just a matter of removing the original 12v bulb and popping in the LED fitting.
    I have mounted the card on a blob of blue tack.
    Its a white light and is really bright and gives a good light especially when the awning is up.
  5. Jim
    Jim Ringleader
    Jul 19, 2007
    26,704
    78,980
    Sutton on Sea
    Hi gwyntaxi, the only thing I can see that you are doing wrong is not reading all the replies that your posts received. Not sure what you are expecting, but the best thing to do is check your own threads when you log in. The best way to do this is click the search button on the top blue bar it is labelled "Search+" then click "view all threads started by you" Click on the picture below it should help. Click on the threads below to see the responses to your previous questions:thumb:
    9 responses to this same question were given here:Smile: http://www.motorhomefun.co.uk/introduce-yourself/13812-ledlighting.html
    3 responses here http://www.motorhomefun.co.uk/motorhome-chat/13841-gwyntaxi-ledlighting-12v44-4-motorhome.html
    Why have I got the feeling that Gwyn is not going to see this:Doh:
  6. staging lady
    staging lady
    Nov 12, 2007
    1,134
    55
    North Wales in the Hills
    Hi,
    Like Brisey we changed our halogens in the rear lounge for led's. We got them at the Newark show in March. We haven't changed the fluorescents in the bathroom,or over the pull down bed yet. big difference to battery drain.
    Lucille
  7. MotorhomeWales
    MotorhomeWales Read Only Funster
    Jun 22, 2008
    21
    West Wales
    Common bulbs would be MR11, MR16 and G4. All these are simple to change in most light fittings. As said before warm white is best, beware cheap LED's, from our experiance the light output is not as good.
    We keep all these in stock and are not a million miles away from you!
    Dan:Blush:
  8. Neckender
    Neckender Funster
    Oct 15, 2007
    1,280
    1,592
    Neckend or Benidorm
    Hi Space runner could you tell me where you got the leds for your awning light.
    Thanks, John.
  9. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    I have always advocated LED lights.Changed them all primarily to greatly extend the life of the Leisure batteries.
    Did all the instrument panel and exterior running lights, brake, side and reversing lights too.
    Money very well spent IMHO.:thumb:
  10. guymid
    guymid Read Only Funster
    Jun 17, 2009
    13
    North Yorkshire
    I've changed all the bulbs to LEDs in my van including the cab ones and the awning ones. It gives us the freedom to use lights as much as we wish without worrying about the battery. I can have all my lights on (about 10) and it use only the same power as my old two main flourescent lights (24 watt each).
    All the bulbs are from Ebay, and most have been straight replacements (ie, take the bulb out, and put the new one in). some I've bought new connectors for and wired them into the existing light fittings so that I can use the widely available and relatively cheap G4s (standard small halogen two pin fitting).
    The best advice I can give is to always use Warm White rather than Day White, and only use SMD type LEDs. SMD LEDs are yellow discs rather than the old transparent plastic dome, and they are much much more powerful.
    Also note that the number of LEDs has no bearing on the light output. SMDs are much more powerful, but the light comes from the size of the discs, and you can get G4's with only 9 larger SMDs on which are just as powerful as ones with 15 smaller SMDs. Many of the ebay sellers show the ratings in lumen (lm) so you know what you're buying. Generally a decent SMD should give you at least 100lm and will be the equivalent of at least a 10watt halogen bulb even though it will only consume 1 to 2 watts.
    Also note that for extra power in my main overhead light fittings I've put 3 or 4 SMD bulbs. This gives strong lighting for less than 10 watts power.
    Oh I can also really recommend the Philips Spot-On stick-on LEDs that are £6 from amazon. I've got one in each cupboard and what's really clever is that they have a built in PIR, they're battery powered and even though you stick them onto a surface, the back (which is stuck on) is only connected to the main unit by magnets so you can just pull the main part off to change batteries (not had to yet in three months) and pop it back. The give enough light to make a difference, to cupboards and are great in your fridge too if you don't have a fridge light like me. I have two in the fridge and when I open the door they automatically switch on and I can see the contents really well.
    If you see us on a camp site, our motorhome is the one that is positively glowing!
  11. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    has anyone noticed where this thread is placed......
    MOTORHOMES IN THE NEWS.
    no wonder it didnt get much early response and no replies from gwyntaxi
  12. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    :Rofl1::Rofl1::Rofl1::Rofl1::Eeek:
    Do you think someone should tell them?
  13. gwyntaxi
    gwyntaxi Funster
    Jun 9, 2009
    170
    63
    waunarlwydd,swansea
    gwyntaxi re;led lighting
    many thanks everyone ,andyes Jim i did see this one:Blush:more by luck than judgment its my own fault i just dont seem to be able to grasp the art of computer
    literacy:Sad:which makes using the website forum seem difficult, well to me anyway
    i;ll grasp it eventually, thanks again everyone :thumb:
