Led bulbs (1 Viewer)
Don't know
44
14
Bolton
Hymer a class
12 month
Looking for advice, I am presuming this photo of the bulb is a halogen, I have uploaded, I would like to change all 7 in total to led lights on my b584 Hymer 2002 model. My questions do I just buy led light and plug in. And his there a certain wattage. And has anybody got any recommendations. Has I don't really want to be buying cheap and nasty. Thanks
andy63
4,672
15,017
south shields
None
since 1990
No experience myself replacing bulbs for led...but from reading posts ,just make sure you get the right fittings and there appear to be all mane of shades of white... It might be better to check them first so you have a pleasing light and not something that is too bright or harsh...
Andy..
Feb 22, 2011
9,763
20,120
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Arten lighting do a good range, I had mine from them to replace lights in Hymer. I went for the soft white
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
That is a difficult one to replace, it's so compact no LED is an exact replacement. I have done many but ended up having to modify the big round ones with extended wires.
Feb 24, 2013
13,054
101,387
Bolsover, Derbyshire
Hymer S800
not long enough
this is what I used, some of mine needed to be the short length to allow doors to open underneath them in bathroom
scotjimland
2,256
9,780
A Woosh bang
Replaced mine in my Hymer 2002, with these.. from Aten lighting.. not cheap and nasty , voltage regulated10-30V, and are not polarity sensitive - i.e. the LED will light up whichever way the positive and negative power is applied so no rewiring is required.
10 LED G4 side pin.http://www.atenlighting.co.uk/10led-side-pin-g4-371.html
Feb 24, 2013
13,054
101,387
Hymer S800
not long enough
Thanks a lot I will be ordering this type now,
they will not fit, you need the barrel shaped ones to be closest to the one you are replacing
more like these
the others will probably do some of the other lights though, we had to use both types, and some others (y)
Don't know
Don't know
44
14
Bolton
Hymer a class
12 month
Just a thank you,I just got back home today, the above light bulbs above have been delivered, and pleased to say all 8 fitted in the motorhome.
