LED bulbs not fitting
Discussion in 'Motorhome Chat' started by GregM, Jun 15, 2010.
  1. GregM
    GregM Read Only Funster
    Nov 2, 2009
    255
    Nottinghamshire
    I purchased a couple of LED bulbs from ebay (hong kong) http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350358325599 to replace the reading lights in our 'van.
    The bulbs in the 'van are BA15s's (I think also referred to as 1156) which so it appeared a straight swap is all that's needed but for some reason they don't fit, you can push the bulb into the socket, and it twists but it doesn't lock into place and drops out.
    Has anyone had this problem or know if there is a way to resolve it?
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,950
    I made exactly the same mistake myself, luckily not too expensive a mistake. The problem is that the bayonet cap isn't long enough so the shoulders of the bulb snag on the fitting and prevent proper location and locking.
    Tried all sorts of ways to make them fit, filing down the shoulders etc and nothing worked. There should be something about it in posts on here from a couple of years ago :Smile:
    The way I resolved it was to buy bulbs similar to These from Aten Lighting.
    You may be able to use your eBay cheapies as stop/indicator bulbs depending on fitting. I ended up giving mine away.
    Graham
  3. dazzer
    dazzer Read Only Funster
    Jul 30, 2007
    1,698
    99
    In my house
    a spot of clear silicone to secure it with the bulb held in place by tape till it dries will solve your problem
  4. GregM
    Nov 2, 2009
    255
    Nottinghamshire
    That's an answer I didn't expect:)
  5. dazzer
    Jul 30, 2007
    1,698
    99
    In my house
    Is that a good thing or a bad thing?? :Eeek:
  6. GJH
    Aug 20, 2007
    27,349
    34,950
    Shouldn't think so. The problem isn't just that the bulb won't stay in place. The bayonet cap won't reach far enough into the fitting for the contacts on the bulb to meet those in the fitting.
    Graham
  7. goffer
    goffer Read Only Funster
    Mar 15, 2010
    77
    15
    weymouth sunny dorset
    led bulbs
    if they are twelve leds you need to swap them for nines they will fit
    Had same problem, but it was rectified.
    Tony
  8. barryd
    barryd Read Only Funster
    Feb 10, 2009
    1,144
    103
    Yorkshire Dales
    I spoke to these guys http://www.campercare.co.uk/Index.jsp and they were really really helpful. I was going to buy of Ebay but there really is more to it than you think. I told them the type of fittings I had and the bulbs that needed replacing and they were spot on. dont think they cost much either.
  9. GregM
    Nov 2, 2009
    255
    Nottinghamshire
    Thanks for the replies, I'll look at the adapters that convert from the ba15s (1156) to M11 or G4's.
  10. schojac
    schojac Read Only Funster
    Apr 25, 2009
    339
    234
    Cambridgeshire
  11. novawight
    novawight Read Only Funster
    May 14, 2010
    639
    235
    Hayling Island
    at the newbury show , aten lighting had a stall, tou could get all the info from them , evev take out your lighting fixture, take it to them and they would give you the equivalent in l.e.d
