Leaving the hook up hooked up (1 Viewer)
grasscutter
2,448
8,366
East Wittering. West Sussex.
Hymer Exsis i588
Started in 1980
Mines been permanently hooked up for five years on my drive apart from when we go away. Never had a problem.
ludo
724
1,178
Lincolnshire
Van Conversion
Since 1990
I expect it depends on what type/make of charging/power unit that you have.
The extract below is from one of the technical pages produced by Atlantic, suppliers and repairers of power systems. http://www.atlanticmotorhomeservices.co.uk/schaudt-elektroblock.php
How to look after your EBL:-
1. Don't continue to use a battery that is past it's best. See our separate page, 'Battery Technology' on how to save money on batteries. When a new battery can cost just £50 it isn't cost effective to damage the EBL by continuing to use a battery that is not at it's peak.
2. Don't cover an Elektroblock with a Duvet, keep the EBL cool.
3. Do disconnect it from the mains/battery before switching the device from Gell to Wet battery type: See the separate Battery Technology page for information on the suitability of Gel batteries in Motorhomes/Caravans.
4. Don't connect the Car to Caravan tow hitch while the Car engine Ignition is 'on' making the 12n/12s charging circuits live and prone to reverse polarity issues.
5. Don't run the 'Mains' supply from an unsmoothed generator supply: The output on these can vary by as much as 100 volts.
6. NEVER run without a battery connected, some Caravan chargers can work in this way, but the strain is significant.
7. Do make sure the mains hook-up is unplugged when you attach/detach the battery cables.
8. Do not leave the Motorhome connected to the mains 240V for long periods when not in use. The units are designed to be connected to the mains for just a couple of months a year. Hooking the MH up to mains for long periods of time will shorten their life.
9. Do play safe during electrical storms. If you are in the vicinity of an electric storm, particularly abroad, cut the mains supply to the Motorhome either by using the RCD or pulling the Mains hook-up lead until the storm passes. Lightning can hit overhead power cables which may lead to higher than normal voltages in the immediate vicinity.
I have spoken to Atlantic about this subject, bearing in mind some of us "live" in our vans during extended holiday periods, i.e. Benidorm lovers, and the hookup can be connected for a signifiant period. They told me that provided 12v appliances are being used and power is being drawn from the system, and the van isn't just standing idle for months, that is OK.
LAM
Apr 23, 2014
415
288
Wiltshire
Chausson 640 Welcome
Began with the purchase of our first, ever MH in 2014
Why would the battery need to be permanently connected to the mains and what is an EBL, please ?
:think:
ludo
724
1,178
Lincolnshire
Van Conversion
Since 1990
:think:
The opening post asked, "will leaving my MH hooked up to 240v cause any damage to the leisure battery?", so you need to ask the OP that question.
In my particular paste, I do have our van connected to the mains throughout the winter because I have a thermostat controlled heater in the van maintaining a 10-12 degree C temerature. However, I switch off the charger and switch it on again overnight every 4 weeks or so to maintain the batteries.
"what is an EBL, please ?" Look here: http://www.atlanticmotorhomeservices.co.uk/schaudt-elektroblock.php
ELB is the prefix to the model numbers of the Schaudt Electroblock range. These are commonly installed in German vans, and are extremely good, in my opinion.
LAM
Apr 23, 2014
415
288
Wiltshire
Phew, a great deal to learn ! Thank you for the above info ludo
Don Quixote
2,966
5,257
Lost in La Mancha, Spain
VW T6 Campervan
Hi all,
Quick question please: will leaving my MH hooked up to 240v cause any damage to the leisure battery?
Regards,
Some reading for you:
Broken Link Removed
Apr 22, 2013
911
660
Cotswolds
Bailey Approach 625
Since 2011
The permanent EHU question, an old chestnut!
There are as many answers as there are motorhomes.
I have read here and other places that some motorhomes have intelligent chargers build in, I can't comment on those as I've never own such a vehicle.
The two motorhomes I've owned in recent years have been of British manufacture (Elddis and Bailey), it may be significant that both companies have a long history in caravan manufacture but who knows. In both these motorhomes the "chargers" are in fact just simple PSUs (power supply units) their purpose seems to be to supply 12V power to appliances from a mains power supply. These PSU are connected in parallel with the leisure battery so the 12V power can come from either the PSU or the battery. It also means that if the voltage from the PSU is higher than that of the battery a charging current will be applied to the battery.
I have attached a battery monitor to my current motor home and can see the operation of this charging mechanism. I can therefore see that the voltage from the PSU varies with the 12V load applied. When there is no load the output voltage is 13.7 Volts, as the load increases the voltage drops. For the technically minded its drops about a tenth of a volt for each Amp supplied.
This voltage of 13.7 Volts is idea as a float charge for lead acid batteries, and I find after an EHU is connect to the motorhome on my drive the leisure battery voltage is 13.7V and the current is flashing between zero and 0.1 Amps. IE about the internal discharge of the batteries.
My conclusion is that in the case of my Motorhome permanent EHU connection is both safe and preferable to keep the leisure batteries is tiptop condition, but as they say on the internet YMMV:unsure:
Gordon
Silver-Fox
9,234
28,706
Cheltenham Spa
Rapido
im a not so newbie
I dont have experience with permanent EHU on a MH but all my road bikes had permanent EHU when in the garage
i used a special type of charger that would condition the battery and keep it topped up
I presume a MH has a similar system
Sift
Sift
107
63
Ringwood, UK
Since April 2014 :O
Thanks for all the responses. There's no specific reason for wanting to leave the EHU in place, other than to be able to switch a fan heater on in the van regularly over the winter. It just saves me wandering in and out of the garage with the lead if there's no reason not to leave hooked up. I will read all the above though.
Thanks again all.
Regards,
