Leasure battery is it terminal
Discussion in 'Tech/Mech General' started by betterthenatent, Sep 16, 2010.
  1. betterthenatent
    betterthenatent Read Only Funster
    Aug 23, 2010
    38
    Hi My leasure battery wont hold a charge I looked at the electrolyte level the other day and all the cells needed topping up. (one other thing that the selling dealer didnt check). I have resignd my self to replacing the battery. But the only thing that concirns me is its demise due to old age or is it being discharged through a leakage some where. Am i right in thinking that If the aux- veh switch is in the centre position then no currant can escape. Also does the veicle battery get charged when the hook up is connected. New to this game so there may be a few more of these silly questions.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,947
    17,616
    YO11 2BD
    put the switch in the center (off) position and the battery will neither receive a charge or discharge through use (though it will 'self' discharge over time) providing nothing is connected between battery and switch.....alarm etc.
    in the center position the charger/power supply alone will power any 12v equipment without charging the battery.
    your engine battery will charge on hookup if the panel switch is set to 'VEH' and, if not hooked up, you can use the engine battery as an emergency leisure battery by switching to VEH, but not advised for any length of time or the engine battery will also be flat when you need it most.
  3. betterthenatent
    Aug 23, 2010
    38
    Thanks for that. We have just got back from two days static with the hook up connected and the switch set to aux. within twenty four hours the volt meter read nine volts. (its lowest reading) The water pump still runs, but lights are dim.
  4. pappajohn
    Aug 26, 2007
    29,947
    17,616
    YO11 2BD
    sounds like your charger is either faulty or turned off as when on hookup and switched to aux the charger will divert power to the leisure battery.
    if you have a volt/multi meter connect it to the battery with the hookup off and note the voltage at the battery.
    connect hookup and recheck....it should read higher with hookup connected.
    if its no different check the charger is on and the fuse is ok....the fuse may be in a linear fuse holder on the charger casing.
    look for a small slotted plastic screw in cover about the width of a toothpaste tube top otherwise check both the 12v and 230v fuse boxs.
    if its all on and fuses ok then i suspect a faulty charger.
    ps...9v is dangerously low, battery health wise, and the chances of permanant battery damage is extremely likely.
  5. betterthenatent
    Aug 23, 2010
    38
    With the hook up connected the leasure battery reads over twelve volts on the control panel
  6. scotjimland
    Jul 25, 2007
    28,934
    25,602
    That being the case and from your own observations, I would say the battery is not just terminal .. but dead .. no change of remission. :Sad:
  7. robnchris
    robnchris Funster
    Jan 11, 2010
    1,350
    1,670
    Chester
    it`s a goner
    It`s off to buy a new battery for you I`m afraid, with a reading of 9 volts the battery is well and truly a goner.
    A battery is considered fully charged with a reading of 12.8 volts, a reading of 9 volts sounds like you have a shorted cell.
  8. pappajohn
    Aug 26, 2007
    29,947
    17,616
    YO11 2BD
    the control panel is reading the battery charger output volts, via the battery,...not the actual battery volts.
    you now need to disconnect the hookup and check the volts again, off hookup, after an hour or so.
