Leaky Pipe (1 Viewer)
tick59
1,413
1,409
Newcastle Upon Tyne
"Since 2005"
:Doh::Doh:
THE PIPE THAT YOU USE TO FILL THE WATER TANK ON MY VAN HAS GOT A LEAK ON IT DRIPPING INTO THE WARDROBE WHEN FILLING UP WITH WATER IS IT A HARD JOB TO REPLACE?AND HOW?
ALL HELP WITH THANKS.
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
Ours consists of a simple piece of pipe with a jubilee clip attaching it at either end. I've neve had to change it but it looks straightforward enough. It may vary from one m/h to another so you may need to investigate further.
Wyn
tick59
tick59
1,413
1,409
Newcastle Upon Tyne
"Since 2005"
:Doh::Doh:
WILL HAVE A GOOD LOOK. JUST NOT SURE IF YOU CAN DO IT FROM INSIDE THE VAN OR IF YOU HAVE TO TAKE THE FILLER OFF THE OUTSIDE ????
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
This should be easy to replace....most dealers would carry spare tube by the metre.
You could also carry out a repair with self amalgamating tape like this one...Link Removed
Brian
GJH
29,450
38,827
None, now sold
2006 to 2022
We had a similar problem with our Autoquest 100. It seemed to be caused by the fact that the pipe was wire reinforced and flexing had caused a split. In that case the filler pipe was easily accessible because the tank was underneath the forward dinette seat but, if the floor of the wardrobe is removable (as it was in ours) it shouldn't be too difficult.
As Wyn said, the pipe is secured by jubilee clips.
I obtained a more solid piece of pipe (no wire reinforcement) from Link Removed, cut it to length and put some clear silicone sealant on each of the male fittings (filler cap & tank) before fitting it and securing the jubilee clips.
TheBig1
17,630
43,262
Another cheaper place to buy the pipe is pet shops that sell aquariums and accessories. Last time I had to replace one, I got the pipe for under ÂŁ5. Replacing is easy dependant on access requiring just unscrewing jubilee clips. If the inside of the filler cap has been covered by the wardrobe, undo the screws on the outside and extract it with pipe attached, having first undone the tank end. Refit the new pipe to the filler and reinstall in reverse, but make a seal to the van with non setting mastic before inserting the screws.
Also make sure it is the pipe leaking, and not the filler, as the joint between them flexes and puts the filler under stress
haganap
12,758
26,447
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Can you just fill it up from the tank? then we can have a look at Eden Camp and get it sorted.
or why don't you get Chris to fix it? :ROFLMAO:
GJH
29,450
38,827
None, now sold
2006 to 2022
Good point Paul.
How long a piece do you need Bill? I've just been into the garage and found the offcut left from when I did ours (never throw owt away). It's just over 20 inches long and you're welcome to it if it's long enough.
It's "shields vac xhd series 148". Can't find any references in this country on Google though.
tick59
tick59
1,413
1,409
Newcastle Upon Tyne
"Since 2005"
:RollEyes::RollEyes:
Can fill the tank up no problem as long as one of us is inside to cover the leak with a cloth,Chris says bring your tools with you to Eden Camp then the two of you can sort it while i supervise with a Pint in my hand.
TheBig1
17,630
43,262
to get by without the leak for now. just push the filler hose, without a fitting on preferably, down the fill pipe past the point where it leaks or into the tank. This way you dont need a second person with a cloth
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
My filler pipe fortunately doesn't leak (touch wood) but would be a right pain if it did because it goes into the tank low down so has water in it all the time.
haganap
12,758
26,447
planet earth
It shouldn't matter anyhoo as neither of ya wash :ROFLMAO:
Ya only need water for Chris's coffee and she can have a flask :Cool:
Graham
Can you bring that spare pipe you have please?
tick59
tick59
1,413
1,409
Newcastle Upon Tyne
"Since 2005"
Good point Paul.
:ROFLMAO::ROFLMAO:
NOT SURE HOW LONG WE NEED IT TO BE CHRIS HAS NOT MESURED IT YET!!!
GJH
29,450
38,827
None, now sold
2006 to 2022
Shouldn't mock the afflicted Paul. They are Geordies after all :ROFLMAO::ROFLMAO:
Graham
Will do. I'll even soak it in sterilising solution :Smile:
I'm pretty sure I've got a couple of new jubilee clips as well.
If you supply the tools, Paul, all that is need is labour - and as the odd one out will be Bill he can do the job whilst we watch :ROFLMAO::ROFLMAO:
tick59
tick59
1,413
1,409
Newcastle Upon Tyne
"Since 2005"
:ROFLMAO::ROFLMAO:
THANKS FOR THE OFFER TO HELP. BUT AS I'VE BEEN ON THE SICK SINCE SEPT 2011. THE DOCTOR SAYS I JUST HAVE TO WATCH PEOPLE WORK AS IT IS BAD FO ME ELF, SO I'LL WATCH YOU TWO DO THE WORK AND HAVE A BEER OR TWO.???
tick59
tick59
1,413
1,409
Newcastle Upon Tyne
"Since 2005"
If I've got that right you are going to watch us have a beer or two. Hope you're buying :ROFLMAO:
:Doh::Doh::Doh:
SUNDAY 11/3/2012 CHRIS HAS DECIDED TO HAVE A GO AT GETTING THE PIPE OUT. THE WARDROBE DOOR IS OFF AND NOW SHE IS TRYING TO GET THE FLOOR OF THE WARDROBE OUT, I HAVE BEEN TOLD TO KEEP OUT THE WAY AS I'M GETTING ON HER TITS. LET YOU ALL KNOW HOW SHE GETS ON.
tick59
tick59
1,413
1,409
Newcastle Upon Tyne
"Since 2005"
:Doh::Doh::Doh:
GOT THE WARDROBE BACK TOGETHER,PIPE STILL GOT A LEAK, MUST BE STUCK ON WITH SUPERGLUE COULD NOT GET IT OFF SO GOING TO TRY AND SEAL IT SOMEHOW???
haganap
12,758
26,447
planet earth
just leave it till Eden Camp and let us [STRIKE][HI]professionals[/HI][/STRIKE] have a go.;
