Leaking window (1 Viewer)
Apr 26, 2014
622
606
Thornton Cleveleys
2004 Bessacarr E735
3 years
We have a 2004 Bessacarr and one of the side windows is leaking. It's got the aluminium framed windows and the water is coming up between the seal and the inner cill.
the same has this.
I believe there's a modification to prevent this requiring drilling of the outer frame and cutting the seal but can't find details anywhere.
Has anyone come across this mod?
Thanks in advance.
ojibway
531
305
Eastbourne
Van Conversion
since 2005
We had a similar problem with our James Cook, MB Sprinter. I tried sealant, added a self adhesive gutter above the window but finally had the window taken out and re-fitted. No more leaking!(y)
scotjimland
2,309
9,980
A Woosh bang
If is a recent occurrence, then I don't think there are any short cuts or quick fixes to doing a proper job..
as said, window out and reseal..
funflair
19,341
30,211
Guisborough
MORELO palace
since 2012
If it is coming in the same place as the video taking the window out of the van won't do a jot for stopping it as the water is coming from the frame not the gap between the frame and the van.
The water must be getting behind the seal at the top or the sides and running down and out the lowest point, I would pull the rubber seal out and give everything a good clean and then as long as it's not damaged just refit and cross fingers.
No doubt you could drill a little hole to let it run out instead of coming in but I would approach the problem first before trying to invent a cure for a problem that should not be there.
Martin
Tom A
Apr 26, 2014
622
606
Thornton Cleveleys
2004 Bessacarr E735
3 years
Thanks for the replies. Been in contact with Brownhills who were the original supplier, who then contacted Swift and between them and found the necessary modification.
I'll try and attach it. It's a mod that very few have heard of but the pdf came from Swift so it's a known fault.
  • Window modification (1).pdf
scotjimland
2,309
9,980
A Woosh bang
indeed.. and thanks for info..
always learning.. :)
