Leaking toilet thread again (1 Viewer)
Feb 19, 2015
1,776
1,249
Norfolk
Globecar Campscout 2013
Since 2016
Sorry - have read all the threads on here but none the wiser.
When we open the hatch in the van to pull out the cassette and empty it, it is often either splashed and occasionally drenched with wee. Mopping out with kitchen roll has become the norm. The sliding part between loo and cassette seems to work fine. Is it something we're doing wrong?
Just bought it and know it should all be working fine.
Hoping it's just a newbie mistake.
funflair
19,281
30,050
Guisborough
MORELO palace
since 2012
To be honest I have never read instruction "how to use the toilet" but I think you have two choices.
1/ leave the flap closed until finished and then open.
2/ open flap and "bombs away".
Under scenario 1/ the seal between the casette and the pan is tested more than in 2/ as it may have to hold back a volume of liquid.
I would have a look at replacing the seal on top of the casette for starters.
Martin
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
Are you closing the blade seal after using toilet and ensuring its closed befor travelling? Contents could swill over the rubber seal causing he problems you mention. Closing the blade valve each and every time and ensuring its closed properly and locked in place (you can feel the extra little click) should solve this. If it doesn't I think it could be the blade flap sealing ring that is u/s.
golly
2,003
69,389
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
We had a similar problem intermittently with our cassette, I solved it by putting a strip of foam (piece of kip mat) under the end of the cassette so that it fitted more tightly against the seal.
Feb 24, 2013
13,032
101,351
Bolsover, Derbyshire
Hymer S800
not long enough
Bit of a long shot, but is there any kind of SOG system fitted, possibly incorrectly or part dismantled? They connect to a valve on top and could lead to leaks if not fitted right?
Other than that it is hard to see how it can leak, have you tried filing it with water and shaking it to se if anything comes out?
Good thing is brand new cassettes are available as a spare and don't cost too much (y)
Dec 12, 2010
5,396
21,440
Cumbria
since 2011
Ours used to leak as you carried it vertically to empty it. I fitted a new seal and it still leaked. The circular blade which slides across to close against the seal has a spigot on the bottom which forces the blade against the seal as it slides on the cam track, mine had worn down a bit, so wasn't applying sufficient pressure to make a seal. I made a small nylon button on my lathe to take up the slack and that fixed it. Try a new seal first, they cost around 10 or 12 quid when I bought mine and if it still leaks, maybe try a new blade as well ? :)
Edit: just seen Golly's post, does your cassette have wheels on it ? I remember someone saying that they wear down over time and don't park up as tightly to the bowl. A quick fix is to wrap a few layers of insulation tape around the wheels to make 'tyres' to reposition the cassette (y)
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
We always close the seal blade after use. Never heard a click lock though. No it doesn't have wheels Jock
denisejoe
5,609
11,973
Warden isle of sheppy
Since 2004
Before you pull the cassette out open the flap for a few seconds,this will any allow water resting on top of the flap to drain into the tank. If this doesn't work a new seal is required. Joe
Aug 27, 2009
19,788
23,049
Hertfordshire
Van Conversion
40 years
The chances of it being the seal between the two parts is unlikely. Under normal usage this seal doesn't have a head of water above it. I would think either another seal below effluent level or an air vent problem. I think parts kits are available from manufacture if it is this problem.
denisejoe
5,609
11,973
Since 2004
Most people flush after use then quickly shut the flap this doesn't allow all the water to drain after a few minutes the water sits on top of the blade.
Joe
Aug 27, 2009
19,788
23,049
Hertfordshire
Van Conversion
40 years
Joe
Perhaps you should ask the poster about her flushing habits.:) I've had a number of toilets, never had a joint seal leak but had other seals leak on occasions. I would suggest leaving tissue strategically adjacent to all joints to judge where the leak starts.
Mr B
990
1,889
Yorkshire
Rapido 7065ff Design Edit
Since 2015.......
We had same thing happen to us.
I looked at buying a freshen up kit (new cassette, seat etc), but couldn't find (at the time) the right one.
Ended up taking the blade mechanism apart..... And giving it a good soak and clean. A bit messy, but it did the trick. Got this pic off the web
Badknee
7,406
411,396
notloB
Vantage Neo
Living the dream.
I've got a leaky seal but it's got bugger all to do with the loo. Tenna for men rules ko (y) :LOL:
funflair
19,281
30,050
Guisborough
MORELO palace
since 2012
Joe
Some people use it with the blade shut.
Martin
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
We had the exact same thing happening with ours on our previous van, C250 model,turned out to be the seal (cost around £10 ) very easy to replace, you can tell when the seals are worn as when you push/pull the lever on the toilet to close the slide from the inside of the van you feel a little bit of pressure just before it seals shut, when they are knackered you feel no pressure when the seal closes on the hatch.
funflair
19,281
30,050
Guisborough
MORELO palace
since 2012
The seal and blade you describe is inside the casette so should not leak into the casette compartment anyway, it might dribble on the way to the dump though so watch your best shoes!! . It is the same seal that seals against the underside of the pan so it could well sort it by default is that is where it's leaking.
Martin
Nov 3, 2013
3,170
9,349
Portugal
Fiat Ducato Auto Wildax
C/van since '73 .M/h.2009
It would appear we had the same problem,Golly,has the right idea,we put two running strips where he wheels track and a strip to support the handle end,sorted.
When the "Bond" between the cassette and the housing is correct,there is a need to push it quite firmly to locate it back into its position.
Silly i know,but you are locating it under the casing correctly ?. I found on one unit,the bump stop did not position the cassette properly,so whenn its in position,make sure the openings line up.
Tea Bag.
PS. I had to struggle to post this,finding other words for...Hole/s LOL
Feb 29, 2012
361
225
Reading & Surgeres France.
Hymer 584
Motor homing since 1998.
Check the pivot screw for the blade lever, mine came loose & eventually dropped out. Result was that blade didn't fully lift up against the seal & set up a slight leak. all OK once screw refitted & tightened.
Barrie.
Oct 7, 2013
5,887
36,861
South Wales
Swift Escape Compact
Since 1988
We had the same problem with a Thetford Casette toilet in a Bailey ranger caravan. On removing the cassette it was obvious that urine and other fluids were leaking into the locker. The space below the cassette was always running with liquid that had to be removed with a sponge or kitchen roll.
Despite several attempts to repair it with new seals etc. Bailey eventually agreed to replace the whole installation, including toilet bowl, Casette pod etc. Our local Bailey authorised repairer changed the lot and we had no further trouble.
If the unit is still under warranty it may be sensible to insist on the same.
Minxy
32,618
66,416
E Yorks
Carthago Compactline
Chances are it's just not pushing up tightly against the underneath of the bowl ... we had this on other MHs and simply putting something underneath the cassette to lift it a little so it fitted tight up solved the problem.
Apr 14, 2008
860
3,706
Cromer norfolk
Bailey approach 745
since 2002
Martin
I couldn't even read when mummy taught me to use the toilet
Bartyfixedit
330
566
Maidstone Kent
Self Build Ducato L4H3
Since 1987
What model toilet? If it's a Dometic 41** or 31** it has to be used flap open.
TheBig1
17,575
42,954
dealing with bodily fluids can be a serious bio hazard especially if they are left to fester. best thing for dealing with a leaking cassette toilet is kitty litter. soaks it all up quickly and gets rid of the smell.
refurbishing the cassette is pretty easy and all the parts can be bought separately on ebay etc. the main ring seal does tend to dry out and become hard. sometimes they can be refreshed by cleaning then soaking in boiling water. then place in a bag in your freezer to help it regain shape. before reinstalling coat it with olive oil.
Sep 15, 2009
1,975
4,794
Sussex coast
Lowline
learning
Are you 100% sure its urine ? I had troubles with mine it was a valve leaking flush water took a while to discover and fiddle to change but not expensive.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
The simple answer is. Do you check that the "Bowl" is completely empty?. Before removing the cassette?. The last flush, before you empty leaves a small amount of water on the surfaces of the bowl, this drains to the bottom (No Pun!) and collects on the top of the seal cover. When you remove the cassette this "Water" which may be Tainted, finds its way into the cassette compartment. I always open and then close the "trap" before going to empty the Cassette.
Pete
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
Thanks we will try that
