Leaking battery? (1 Viewer)
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
When I was fitting my solar panel last week I took out my Battery to give everything a good clean out, only to discover wet underneath it and a bit of corrosion, strange thinks I wonder why? anyway the battery didn't have a overflow tube only a hole so I thought that was the likely suspect as there was a wet trail down that end of the battery.
So gave everything a good clean out and covered all corrosion with waxoil and just in case replaced the battery on a bit of thick waterproof plastic and glued a bit of tube to the overflow hole, job done:Cool:. Go back to check everything yesterday only to discover quite a bit more acid on the plastic:Doh: had a look and it looks like its leaking from around the top flange if you get my drift, the bit you lift with your fingers if it hasn't got a handle, funny thing is the battery seems ok, plenty of power, all the cells seem to have plenty of acid with no need to top up.
Just wondered if anyone else has come across this before????:thumb:
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
It could be bubbling over when charging -through the vents in the top up tops ?:winky:
terry
ps paint some rust preventive on the rusty bits
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
We noticed our batteries were not performing as well on the solarpanels. The van was 8 months (3 year old now) old when we bought it and not knowing what the previous owner had done (could have run them flat) we decided to change them.
When the old batteries were taken out one was goosed and the other was leaking from the terminal post. So not uncommon methinks. :Smile:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
I've come across lots of leaky batteries in my job!
It's quite common for cases to fail at the seams.
wizzer59
Apr 18, 2009
3,569
3,367
Hymer B584, A Class
Not long enough!
Ah ok, well I had a good look at it today and it is leaking in one place, so gave it a good clean and filled all around with sikaflex 221, so hopefully that will do until I have a good look around for another, as I said it is fine in every other way and even if it does leak some more at least it can't do any harm:RollEyes:
Thanks for all your help guys, erm, anyone know where I can get a good battery for a reasonable price:Blush:
Tim
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Tim[/QUOTE]
No such thing unfortunately!::bigsmile:
wizzer59
Apr 18, 2009
3,569
3,367
Hymer B584, A Class
Not long enough!
No such thing unfortunately!:BigGrin:[/QUOTE said:
:roflmto::roflmto: So it would seem from what Ive read on here all leisure batteries are crap and the only ones worth buying are traction batteries and I can't afford those:Blush:
