Leak from push fit 't' connector HELP!
Discussion in 'Motorhome Chat' started by Goldilocks40, Oct 19, 2013.
  1. Goldilocks40
    Goldilocks40
    Sep 18, 2013
    38
    8
    Gloucestershire
    Morning all
    Just trying out our van for first time and we have got a big leak from a 'T' connector after the pump (rear dinette got flooded last night) would really appreciate any advice please on sorting this please.
    Dawn
  2. cranky
    cranky Funster
    Oct 29, 2012
    401
    461
    essex
    push fit rely on the pressure to seal the joints. usually when they leak it is because there isnt enough slack in the pipe and when the pressure is off the joint comes apart. Once they go it is normally best to replace but if thats not possible check the O ring inside it is not kinked at all and the pipe is not damaged at all. You may need to cut a bit off the end and remake the joint. Hope you can sort it.
    C
  3. Silkcut1105
    Silkcut1105 Funster Life Member
    Jun 3, 2011
    772
    972
    Swansea
    first thing u must do is turn off the pump .then try and push the pipe in to the tee piece a bit further if that dont work drain the pipes and take the tee off u do that by pushing the round ring on each of the connecters in towards the centre of tee and clean and then refit .hope this helps turn all taps off then put on pump bleed slowly through cold water tap and then hope its ok .good luck.
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,909
    17,578
    YO11 2BD
    the end of the pipe must be cut at 90deg to the pipe and the first inch must be unmarked....even scratches can cause leaks.
    if it still leaks the damage may be in the T piece so needs replacing.
  5. Goldilocks40
    Goldilocks40
    Sep 18, 2013
    38
    8
    Gloucestershire
    Thanks guys, we are off to local caravan shop to get parts this morning...on a fully serviced pitch so have tap and water on hand.....feels like we're camping in a tent again lol x
  6. Paramotormanal
    Paramotormanal Read Only Funster
    Aug 29, 2012
    82
    56
    Kingston upon Hull
    I agree with all of the above but I would consider swapping the fittings and pipe to the Hep 2o fittings and pipe as these cannot unmount in the same fashion.
    This will be my winter project as I have had a similar problem with these fittings weeping from time to time also whilst I am swapping them over I can insulate all the pipes.:thumb:
  7. TheTwoOfUs
    TheTwoOfUs Funster
    Jul 24, 2009
    2,627
    7,333
    South Yorkshire
    You say that you were using the van for the first time. Does this mean that it has been stood for a while? If so, then it's possible that the O ring could have 'set'. In which case it will need replacing.
  8. Biged
    Biged Read Only Funster
    Sep 21, 2012
    159
    80
    Nottingham
    Change the fitting, do not bother trying to do anything with the original.
    Do not bother with Hep2O, Speedfit are what you want, I have fitted thousands of these and they are the easiest to fit and can be dismounted (thats a plus point, not a minus)
    You can get Speedfit at any plumbers merchants, B&Q if you want to be robbed or eBay, they come in various sizes, just measure your pipe dia. If the pipe is manky you may need to add a bit in which case you will need one or two straight connectors to add a new bit and some pipe. If its plastic pipe you may need a couple of inserts if metal not :thumb:
    Any problems just let me know and i will try to help
  9. FULL TIMER
    FULL TIMER Read Only Funster
    May 31, 2012
    796
    712
    NORWICH
  10. wasp
    wasp Funster
    Dec 21, 2008
    2,730
    1,066
    Mansfield
    I got some in Mansfield from my local merchant also got 12 mm red an blue pipe:Smile::Smile::Smile:
  11. FULL TIMER
    May 31, 2012
    796
    712
    NORWICH
    most of them around here don't seem to stock any below 15mm , seems they only cater for standard household sizes. can only get the 12mm stuff from local caravan places or our usual supplier Grass Routes Leisure
  12. Biged
    Sep 21, 2012
    159
    80
    Nottingham
    Just search eBay for 12mm speedfit, there are a multitude :thumb:
  13. hoot007
    hoot007 Funster
    Aug 19, 2010
    271
    271
    trawden lancs
    We had same problem in a difficult position it only needed pushing in another 1/4ins needs a lot of force for a pidling plastic pipe
    John
  14. Tootles
    Tootles Funster
    Sep 14, 2013
    9,135
    32,604
    Lancaster
    I had the same problem on our narrowboat, but just couldnt get the 'positional push' to shove the thing in a bit more, so I made up a string tourniquet, and wound the bl**dy thing into place. Worked a treat. :thumb:
