Leak from internal water tank?
Discussion in 'Tech/Mech General' started by apollomtb, Aug 26, 2011.
  1. apollomtb
    apollomtb Read Only Funster
    Jul 2, 2011
    22
    Stockport
    I have just had a problem with some damp around the seat base of my Hymer (B544 1992) which houses the internal water tank. Initially I though the tank was overfilled so reduced the level somewhat but still damp. Having drained all the water out the carpets dried over night which makes me wonder whether there might be an issue with the tanks itsef? Has anyone else got experience of this as I am still very much a newbie:Smile:
    Many thanks
  2. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,938
    1,957
    Warwickshire
    We had this problem a couple of years ago. There was nothing wrong with the tank, but the culprit was the pump connection in the tank cap (see image). The Reich pump (yes they may be branded Hymer but it's a standard twin-barrelled Reich pump) runs at constant, full pressure. Any water not needed at the outlet tap is returned to the tank via a return pipe. That is why there are two pipes connected to the tank cap. If the seal around these pipes, where they pass through the cap, degenerates then the pump can merrily churn away and shove water up and over the cap.
    If yours has the same system, I would start by checking this area.
    • Like it Like it x 1
  3. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    We had probs earlier this year from same area if we travelled with tank full.
    All the seals were bad,but the worst were the ones at top right of tank where pipes and a cable either entered,or came out of the tank.
    Mike.
    • Like it Like it x 2
  4. apollomtb
    Jul 2, 2011
    22
    Stockport
    Dear JeanLuc and Mike and Carolyn
    Thanks for your reply helpful posts. Looks like seals might be the problem then. Do you know where I would get new ones?
    Best wishes
    :Smile:
  5. MikeandCarolyn
    Mar 18, 2008
    2,171
    1,463
    I'm afraid I took the easy way out-van was going in for MOT at my local Motorhome guru's so I asked to him to sort it for me :BigGrin: And did mention that it had been ok before his guys took tank out to run some wiring behind it-don't think he charged me at all :Rofl1:
    Mike
  6. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,174
    14,066
    Heavan
  7. apollomtb
    Jul 2, 2011
    22
    Stockport
    Thanks Hagnap Ill explore those links
  8. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,938
    1,957
    Warwickshire
