Lead help (1 Viewer)
pvw10
273
45
Gloucester
Coach built
since 2011 after tugging.
Hi all, I wish to put a second leisure battery in so can anybody tell me where I can buy the "male" to hook into the plug shown in my hand ?
If this fails obviously I will just wire it in but would rather "plug and play"
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
That looks wrong from here, the cables on our leisure battery are at least 4 times thicker than those. I can't imagine stuffing 20A charge down those. Are some more hidden from view ?
pvw10
pvw10
273
45
Gloucester
Coach built
Really, bummer.
No that's how it came from the maker, similar to my Apache and I thought as you that they looked thin.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
From the picture they don't look thick enough to run a single cigarette socket let alone central heating, lighting, TV and charge a laptop at the same time.
Odd !!
pvw10
pvw10
273
45
Gloucester
Coach built
Odd !!
One things for sure next time in use I'm going to be feeling the leads to ensure there not to hot !
rainbow chasers
3,680
1,725
Mid Cornwall
Various
If it is the modern thin wall, it should be 2.7-3.3mm thick to handle the charging which would give you around 30-40a - thicker the better really!
pvw10
pvw10
273
45
Gloucester
Coach built
Ah that's a relief, from memory it is easily that or possibly a tad thicker so I happier now.
Thanks to all
tonka
10,823
21,514
Cannock, Staffs
A class Burstner 800
Since 2000
The sergent lead is fine and they supply that to Autotrail.
I had one fitted on my old 700 and have recently fitted same with an extra 110 battery to the new 700...:thumb:
Pity, as I just sold one at Stratford for £10 !!!
pvw10
pvw10
273
45
Gloucester
Coach built
Aaaaaaarrrrrrggggggghhhhhhhh with post I just paid about £19
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
And the connector ?
Thin wall tin connector. Must be rated OK on paper, but with a few years UK weather tarnish, things can change.
I'd love to put a good load on a socket and measure the voltage drop.
I'm a great believer in "if it looks right". Years ago I used to buy the odd Russian meter. Crude and looked like they were designed by a tractor designer but first look said "that won't break". And if it did they usually supplied a load of spares in the box.
tonka
10,823
21,514
Cannock, Staffs
Since 2000
And the connector ?
I had the same lead on my old van for 5 years, never gave me any issues. It's the same cable they use from the charger down to the battery and from the battery feeding back to the PSU so must be suitable... Agree it does look a bit thin when you compare to what we would install if doing it ourselves...
rainbow chasers
3,680
1,725
Mid Cornwall
Various
And the connector ?
I agree, I am not that happy with thin wall - it performs as it should, but isn't all that practical in the real world. They brought it out, purely because the amount of wire in new vehicles - they needed to cut the loom size down - and thin wall was the result. It carries more amperage, and on paper is better.
That said, in many applications I replace with old thick wall as it is more practical. Typical example is roof furniture (taxi lights etc) where many users will feed through the door apeture, they cannot cope with that level of abuse for very long at all - whereas the thicker stuff can. On paper the thin wall is capable of the power demand, but breaks very quickly when abused.
Working with it can be a complete pain too - try to strip it, and it just breaks off! Much of the electronics run off a similar size that you see inside of your printer cord. Hell to work with!
