Latching relay? (1 Viewer)
Sep 12, 2012
1,682
3,335
Wengen
A/S Broadway EL 2021
Since 2010
This may sound a silly question but I need a bit of advice. I have a 12v push button intermittent switch, ie. only sends current when held in.
I want to use this to turn on & off a small LED light, can I do this using a relay & if so what do I need? I can provide a permanent fused 12v feed to the relay. Changing the switch is not an option as it matches everything else on a panel
3
34127
Yes you can use a latching relay but you have to be able to remove the 12v supply for it to switch off which may mean having a separate off button.
43,304
49,292
Easy....
Switch needs disconnecting fully and one side sent to earth...other side to relay as shown..
that will be an earth trigger switch as shown.
red to 12v supply
purple to 12v accessory.
Broken Link Removed
Broken Link Removed
Pat4Neil
1,247
494
Essex
Mercedes
7 years
It might be worth considering changing the switch to a latching switch as oppose to a momentary switch, which is what you have now
Neil
Glandwr
Banned
Jul 10, 2014
1,057
3,301
the Berwyn Mountains
Hymer S740
since 2009
I'd love to be let off duties by claiming that I have to keep my finger on the button. Is that not an option?
Dick
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
.................... or better still one of these:
Broken Link Removed
I never new they existed but I had to look for a better deal (y) £21.50 delivered rather than nearly £30
Broken Link Removed
