laptop lead
Discussion in 'Computers' started by Figaro, May 20, 2016.
  1. Figaro
    Figaro Funster
    Feb 22, 2011
    989
    783
    Newcastle under Lyme Staffordshire
    EBay item number (sorry can't post a link)
    111901886289
    Could I put a 12volt cigarette / hella plug on this to run my laptop in the van ? Rather than the mains lead.
    TIA
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,140
    15,091
    Leeds the one up North
    I doubt your laptop is 12 volts
  3. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,941
    Short answer is probably no as most laptops require more than 12v.
    I've been using a universal adapter similar to This One for many years to recharge the battery on a number of laptops. There are different ones on the market and you need to ensure that you buy one capable of the correct output voltage and with the right tip.
    Alternatively you may find one in This List which is specific to your HP laptop (I assume it's an HP as the lead you mentioned is for HP).
  4. scotjimland
    Jul 25, 2007
    28,934
    25,603
  5. Bailey58
    Bailey58 Funster Life Member
    Jun 23, 2010
    6,591
    10,225
    Norfolk and Toftir.
  6. Figaro
    Figaro Funster
    Feb 22, 2011
    989
    783
    Ok, probably wrongly assumed laptop was 12volt
    I'll check transformer thingy when I'm home later.
    Just a mad thought whilst at work, better go do some work then......
  7. Poohbear
    Poohbear Funster
    May 18, 2015
    269
    433
    Worcester
    No because your laptop is unlikely to be 12V. They are usually 19V. You will need a proper car charger.
  8. Techno
    Jul 28, 2010
    14,140
    15,091
    Just type the make & model of your laptop in the search box (ebay) followed by car charger and it should bring up plenty of choice
  9. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,086
    6,083
    West Sussex
    Most are 19v and lot of the modern ones have a centre pin which is a smart charger sense pin. This company can supply chargers for most laptops it was the only place I could get one for my new HP, if you can't find your model listed there is an enquiry form.
  10. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    3,737
    8,824
    NW England
    The universal 12v to variable voltages up to 19v seem to work OK for me. They usually come with a range of end plugs too. Even if the end plug isn't right it's easy enough to connect the right one to the wires with a bit of patience and a soldering iron. Just remember the stripy wire is the positive one.
    I've also got a 12v to Macbook adapter, a Chinese one which violates the Apple patent on the Magsafe plug, but at a far more reasonable price than the ridiculous sum demanded by Apple. Works fine.
Similar Threads
  1. ShiftZZ
    29
    422
  2. Gromett
    240
