Laptop charger problem Help please
Discussion in 'Tech/Mech General' started by gazza280, Oct 28, 2013.
  1. gazza280
    gazza280 Read Only Funster
    Sep 26, 2012
    98
    356
    Worthing
    Hi Guys
    Gotta bit of a problem with laptop charging problem is I have a universal charger/adapter that should, when plugged into the 12v, charge the laptop battery and allow me to use it off hookup but after about 5 minutes the fuse blows in the adapter.
    I have used 3 different adapters and the same thing happens every time. I have used the mains charger in an RAC 350w inverter and plugged that into the 12v but it makes a loud screaming noise, the fault light doesn't come on but it does still charge the laptop battery. Though I can't stand the screaming noise.
    Any ideas? Any help would be appreciated.
    Thanks Gary
  2. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,782
    10,197
    the universal charger is pulling too much current to supply the laptop's needs. make sure its capable of supplying at least as much power as the genuine charger. also make sure the socket and its wiring is capable of supplying the current needed and the voltage is not dropping due to length of wire run. the inverter is not working properly if its screaming. may be low voltage getting too it. best wired direct to battery not plugged into a socket as these are only low current rated and voltage drops the longer the run of wire.
    • Like it Like it x 1
  3. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,518
    Tyne & Wear, sometimes..
    I would buy the proper manufacturer's replacement charger.
    They are not normally that expensive.
    It should be rated accordingly to do the job.
    • Like it Like it x 2
  4. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    In addition to the sound advice given above, is the universal charger set up correctly so that the output voltage matches that required by the laptop?
  5. Wissel
    Wissel Read Only Funster
    Sep 16, 2013
    301
    323
    Cornwall
    Do you know how many amps your laptop pulls when charging?
    It should say the voltage and amps on the original charger.
  6. Tootles
    Tootles Funster
    Sep 14, 2013
    9,267
    33,247
    Lancaster
    Also, be very careful with inverters. Unless its a very expensive model, chances are its not pure sine wave, which will then run a conflict between itself and the charge adaptor. I saw a charger catch fire on a boat once for the very same reason. Same with certain cheap generators.
  7. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,046
    13,906
    Bolsover, Derbyshire
    Before I added a second battery and solar panel I had similar issues with my inverter, but by starting the engine the problem went, so either charge while on the move or run your engine while charging, I found that after a few minutes top up from the engine the inverter worked anyway. Clearly a low voltage issue in my case, possibly a combination of laptop very low and MH battery a bit low
    I hope this helps a bit if you are stuck, although technical comment above makes best sense long term
    David
  8. JJ
    JJ Funster
    May 1, 2008
    14,904
    26,733
    IMO TheBig1 had it 100% correct and explained it perfectly...
    Laptops can pull a lot of current...
    JJ :Cool:
  9. hilldweller
    Dec 5, 2008
    27,567
    26,682
    Macclesfield
    An emergency work-around is plug in to charge but don't turn on. They eat far less just charging.
