Laminate flooring also generator offer
Discussion in 'Motorhome Chat' started by VMax666, Jan 8, 2010.
  1. VMax666
    VMax666 Read Only Funster
    Nov 26, 2009
    172
    Knutsford
    Looking at laminate flooring in B&Q, wondered if it was worth doing the Hymers floor to replace the carpets. Easier to clean etc. Any pros and cons?
    Also spotted a 2.5Kva generator on offer at £129.95, no weight on box but it did say 96db!! Ear plugs a must then.
    VMax666
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
    laminate flooring looks very pretty but have you checked the weight of it !!!!!
    a fair chunk out of your payload.
    much better with a good quality vinyl
  3. wasp
    wasp Funster
    Dec 21, 2008
    2,733
    1,072
    Mansfield
    We took the original carpets out of our Buccaneer and bought a piece from the carpet shop used the old ones for pattern and stowed them away. This way you keep the originals and just chuck the others away when they get really filthy I am on my second set of throw aways and the only cost about £25.00.:thumb::thumb::thumb::thumb:
    Hope that helps Cheers RobBTW I have had the MH 5 yrs
  4. M&L
    M&L Read Only Funster
    Jan 26, 2008
    75
    North Lincolnshire
    I would not consider laminate flooring as it would be impossible to fit and make a decent job, it's bad enough in a room at home and that's apart from the weight.
    If the existing carpet is not good then cut it out and use it as a template for another one.
    Mike
  5. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,857
    6,110
    Mansfield,Notts
    Two main probs with laminated flooring are,
    1. Fit as per instructions ie leaving a gap around the edges (needed for natural expansion) and it moves opening up between the joints, and looks crap when dirt gets in between the open joint and you cant close them up again
    2. Fit tight and due to expansion the joint "kiss" and buldge upwards, looks crap and poorly fitted
    xperts will tell you click laminates are not suitable for Motor Vehicle instalation.
    Far better to get professionally fitted Rhino floor (H/duty vynal) in a wood effect pattern,warmer/softer too:thumb:
    Geo
    Posted via Mobile Device
  6. gwnking
    gwnking Read Only Funster
    Sep 29, 2009
    521
    East Anglia
    Our Roller Team has factory fitted vinyl looking laminate. Its ideal when its wet as the floor can be wiped and doesnt collect the dirt like carpets but I am thinking about putting some carpet down for warmth.
  7. bazfergy
    bazfergy Read Only Funster
    Apr 20, 2009
    566
    3
    dumfries scotland
    Go for the vinyl,the laminate will be lumps and bumps after your first drive:thumb:
  8. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,015
    5,342
    Wirral
    My new Hymer,currently in build,will have a laminate vunyl floor covering and removable carpets as standard.
  9. savantuk
    savantuk Read Only Funster
    Jul 3, 2009
    751
    38
    Cumbria, Lake district UK
    Our Hobby has a beautiful wood laminate effect vinyl floor cover fitted from new, and very nice it looks too. A warning though, we have loose fitted carpets on top, and grit get's beneath it, we had a small hole near the fridge where a piece of grit got trapped, and punctured the surface of the vinyl.
    A local carpet fitter filled the hole with coloured vinyl repair paste, and it's invisible now, but it cost £40!! Expensive bit of grit:Eeek:
  10. VMax666
    Nov 26, 2009
    172
    Knutsford
    Thanks for advice, had not occured to me that the laminate floors I had seen in vans was vinyl not the real thing. Currently has carpet over vinyl that looks dated and scruffy, so may sit in there one day with a cuppa and consider the options.
    VMax
  11. pappajohn
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
    if you do replace the vinyl ensure you glue the edges down well, especially in the kitchen area.
    the last thing you want is any liquid, spillages etc, getting underneath and starting to stink.
