Laika underseat blower (1 Viewer)
Sift
107
63
Ringwood, UK
Since April 2014 :O
I'll post in the Laika specific forum too but does anyone know which button on the dashboard should activate the hab underseat fan that blows hot air from the radiator that's served by the engine coolant. I have two possible candidates (as well as a rear window heater switch with clicking relay!), as attached, but neither appears to do anything.
Regards,
Lee.
Ridgeway
3,623
6,051
Lausanne
NiBi Arto 85E
Since 2012
Ours is on the LHS of the steering wheel (LHD) and is a switch with a fan symbol on. This is on a Ducato cab.
Couldn't see anything attached ?
BwB
917
1,171
Suffolk UK
Resting b'twix vans
Since 1990
On my 2003 Fiat its a button with a fan symbol and red led to the right of the lever which does the fresh/recirculate air flow in the middle of the dash where all the other heater controls are. My rear heated Window button (which in reality just does the heated door mirrors) is one of the five buttons in the row with the hazard button.
You should be able to tell as the auxiliary rear underneath fan will come on (you can hear it). You may find, though, that it only blows cold air as they are prone to airlocks and maybe the valve sticking.
Sift
Sift
107
63
Ringwood, UK
Since April 2014 :O
Thanks for responses so far. I've now attached the photos :Doh:
The radiator gets lovely and warm and does provide some heat but think I could probably do some toast on it if it was blowing :Smile:
Cheers,
Lee.
BwB
917
1,171
Suffolk UK
Resting b'twix vans
Since 1990
Press both buttons - if neither starts the fan then check fuses :Smile:
It's a chassis part fitting so will be in with the other engine fuses not any conversion fuses.
10,126
56,774
Market Harborough
C Class Laika Ecovip 7R
On our Laika ecovip 7r it's the switch with the fan and you can hear it when you switch it on and it really heats up quite quickly. :thumb:
Sift
Sift
107
63
Ringwood, UK
Since April 2014 :O
Thanks David and Ridgeway. At least I have a lead now, rather than wondering if it's the correct button. Now to start looking at fuses but maybe will test voltage at fan first.
Gawd knows what the other little switch is for.
Regards,
Lee.
