Ladder for pull down bed. Painfull (1 Viewer)
Gunner
87
47
Shrewsbury
Hymer c544gt
1 year
Hi can anyone help We have standard wooden slat type ladder in our hymer 544 gt And it really hurts our feet getting up and down. We love the layout and are fairly fit. But the ladder seem useless. Can anyone suggest a better ladder. Thanks in advance
cliffanger
4,793
33,793
Saltford
Hymer A class
Since 2013
We use one like this made by Abru - as long as your layout has enough space to open it up during the night, it stays up on the bed during the day - works perfectly for us.
Gunner
Gunner
87
47
Shrewsbury
Hymer c544gt
1 year
Thanks is it high enough. That my only worry but nice wide steps
Aug 6, 2013
11,941
16,532
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I don't use the ladder. One foot on side seat, knee on edge of bed, into bed. If you need to use the ladder have you considered wearing slippers & removing them once on the bed? Or one like this (maybe modified) :
Broken Link Removed
Gunner
Gunner
87
47
Shrewsbury
Hymer c544gt
1 year
Thing is the bed is high and you need 5 rung ladder to get up and in. But a least once up it's comfy. But. Really bad ladder design. Slippers. Uuummm. I think the dogs might like them more than me. (Dogs love to chew slippers).
TheBig1
17,509
42,755
have a carpenter make a replacement ladder with broader rungs using the original to match height and spacing, and of course you could glue on some urethane foam. I used a couple of pieces from a camping roll mat on a ladder in a previous van. this worked very well on the metal ladder with wooden rungs
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Get some foam insulation for 22 mm copper pipe (from a builder's / plumber's merchant or a DIY shed). It is part pre-split so easy to work with and fits neatly over the rungs. Then seal it along the split with duct tape. You may need to replace the foam from time to time but it's cheap and keeps the ladder light in weight without resorting to heavier contraptions.
JockandRita
11,402
148,457
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
@Gunner. That's exactly what I would suggest too. Start simple, and work your way up to something that suits.
BTW, it sounds that you are getting away lightly.........so far. Ask @ianthebuilder how he gets on with his bed ladder. :LOL:
Cheers,
Jock. :)
Hymie
810
1,005
Essex
Classic Hymer B564
Since 1981
We have a B564 and didn't like climbing the ladder, and as it has a single step at the jab door I bought a double step, works as night time stairs to the bed and an easier exit from the van during the day.
It sits under the table during travel.
Oct 7, 2015
736
3,576
newark
Swift escape 624
We cut a set of alloy steps up ,cut the hoop off the top and fitted the hooks to it .made life much easier on the feet
Apr 10, 2010
548
538
Bedfordshire
Carthago
Since Sept 2003
This works well but I recommend double sided tape inside the foam tube as well to stick it to the rungs. Otherwise, depending on the style of the rungs, the foam can spin round the rung causing you to face plant into the ladder. This is the voice of experience.:(
Steve devon
307
326
North devon
Adria sonic supreme
Since 2015
I cut up a foam yoga mat, glued it to the top step and wrapped it around a few times, a cable tie each end, with the join under the slat, works very well
Gunner
Gunner
87
47
Shrewsbury
Hymer c544gt
1 year
Hi thanks for the many suggestions. I'm going with the personal rocket pack for the wife. But I'll struggle along with foam padded steps. For me. Always seems obvious after. Thanks folks.
cliffanger
4,793
33,793
Saltford
Hymer A class
Since 2013
The abru steps we have are brilliant. Very sturdy and just the right height. The arch frame at the top gives you something solid to hold onto when climbing out in the middle of the night. Much safer than trying to negotiate the ladder, when half asleep, with nothing to hold onto.
Jaws
23,821
71,972
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
We went with pipe insulation and held in place tastefully with gaffa tape !
GWAYGWAY
4,213
3,305
Dover
Hymer ML I 580
4 years
My Chausson had an alloy ladder that was very narrow treads and I put thick pipe insulation around them but still not good. My new Hymer has a wooden ladder that is wider but still too narrow for bare feet, however they did make it 3 inches too short and it is virtually vertical so I had to add wooden bottoms to the actual frame to make it climbable, in the end I just climb on the table and seats to get up.
Answer is to wear a pair of Pit boots, in bed
