La Mailleraye sur Seine Aire (1 Viewer)
Nov 4, 2011
5,938
38,893
Uk
Going to be using the Aire at La Mailleraye sur Seine next week and wondered if anybody has used it since the new barrier was installed, as I would think it would now be in action and what are the charges now.
Easyliving
956
2,021
Norfolk
Since 2011
I suppose you have been to this aire before but in case you haven't this is the most recent Youtube video showing the aire by Funster Keith Chesterfield. No barrier when the video made.
Paul
KeithChesterfield
528
1,234
Stand Road Chesterfield
Low Profile
Since 2010
That video was in 2015 but we also went last year and there wasn't a barrier.
But barriers are being put on some Aires - Equihen Plage has one now - but where did the OP get his info about there being a barrier at Mailleraye?
:france: :france: :france: :france:
Dec 7, 2009
307
295
Macclesfield
Knaus Sun Ti
Since Dec 2009
No barrier at Christmas.
jimiol
198
143
Doonbeg Ireland
Coachbulit
beginner, I don't like the newbie term
The barrier was there mid February but not in use then. Think it was going to be €5 payment at barrier not sure if the service point then had an extra charge it wasn't working when we were there.
Manic
Nov 4, 2011
5,938
38,893
Uk
Yes we where there on 29th December and no barrier then but I knew DavidG58 had showed the new barrier had been installed.
Jun 17, 2012
2,932
9,920
North Essex
Autotrail Delaware
>12 but <13
Can't dispute that picture. Being cynical though, how does one turn around when machine is faulty and there is an impatient Frenchman (other nationalities are available) behind you and won't lift barrier, that machine is some way down the track ?
Minxy
32,646
66,526
E Yorks
Carthago Compactline
Is it just me or does that last picture that @DavidG58 has posted look like the payment post has been 'cut and pasted' onto the image ... it just looks weird ... David ... you're not doing an early April Fools joke are you???? :D2;)
Jul 5, 2013
11,723
13,702
Since 2013
Like most other Aires with barriers then!
But from memory the area on the left of the picture had a wide gravel area that could be used to turn around in. What surprises me is the big gap to the left of the barrier that a motorhome could easily drive through. I can see some ticket dodgers using that. Probably the same ones that used to arrive just after the little man had done his rounds in the late afternoon and leave just before he came back in the morning.
Jun 17, 2012
2,932
9,920
North Essex
Autotrail Delaware
>12 but <13
But from memory the area on the left of the picture had a wide gravel area that could be used to turn around get stuck in. What surprises me is the big gap to the left of the barrier that a motorhome could easily drive through. I can see some ticket dodgers using that. Probably the same ones that used to arrive just after the little man had done his rounds in the late afternoon and leave just before he came back in the morning.
Edited for accuracy :whistle:
Minxy
32,646
66,526
E Yorks
Its probably a trap ... I bet if you tried you'd sink into the gravel! :D2
Feb 24, 2013
13,079
101,442
Bolsover, Derbyshire
Hymer S800
not long enough
Oh that I had such ability, getting photos on and the right way up are close to my limit :)(y)
Jul 5, 2013
11,723
13,702
Since 2013
When we were there last September one motorhome pulled into the gravel on the way out to make some last minute adjustments and they managed to pull out just fine. And cars were using it to park on.
Feb 24, 2013
13,079
101,442
Hymer S800
not long enough
the barrier was one of the lightest weight I have ever come across, think it might not survive a gently push o_O
not sure about the turning options and it would be a decent reverse on a wet dark night, but as already said, not a lot different to a good few we have failed to enter o_O
we do like the free ones :)(y) very happy to spend in the town instead of at the barrier :)(y)
Feb 22, 2011
9,785
20,150
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Do those payment posts just take credit / debit cards or cash as well ? And do you have to enter a pin ?
Feb 24, 2013
13,079
101,442
Hymer S800
not long enough
that one definitely has no cash option, so presume the keypad must mean pin numbers are used
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
We were there a couple of weeks ago and I can confirm @DavidG58's photo is correct.
It will be payment by card but when we were there it wasn't in operation so was still free. No signs with payment rates up yet and there is room to sneak round the barrier (the gravel/grass has reinforcing under some of it) but I bet a large rock will be placed there soon. Not sure how the occupant of the small bungalow or visitors to the chapel will get through unless they will be given a pass of some sort.
If you arrive and the aire is full it will be a bugger to get back out, particularly when there are lots of cars parked on the gravel area beside the restaurant.
Richard.
Jul 13, 2008
3,738
3,854
Low profile
Call me tight, but if you're paying €5 or €6 to park water should be free not be an extra €3.
Tight a##e...
May 31, 2015
11,679
44,501
Cornwall
Ducato PVC
Getting Better
so who will not go to this town now...? Will it mean the end of a good Aire...(n)
Feb 22, 2011
9,785
20,150
Hymer B544 A Class
Since 2015
I had it planned as a stopover in June after all the funsters recommendations. The thought of having trouble getting out if full is a bit off putting though, especially if you discover it's full after paying ?
Jul 5, 2013
11,723
13,702
Since 2013
AFAIK it has always been a paid Aire, so nothing changed there. And it is usually busy from spring to autumn. The only difference is the method of payment, which we actually find easier. I expect the little old man who collected the money before will be able to retire now.
Jul 5, 2013
11,723
13,702
Since 2013
Just park by the barrier and walk along. You will soon see if there is any room. If it is full there is a private Aire about a mile upstream.
KeithChesterfield
528
1,234
Low Profile
Since 2010
For a few Euros you get a riverside view of the ships and cruise boats, quiet at night, safe and secure, restaurant and bar 50 metres, Vet who charges less than most Vets in France, two boulangeries within 100 metres, walks along the riverside in both directions for miles - WTF more do you want for your money?
Jul 5, 2013
11,723
13,702
Since 2013
Could not have put it better myself.
And a nice little supermarket within walking distance to pick up all the food you need.
