kontiki skirt (1 Viewer)
color4501
9
Powys
coachbuilt
"I'm a newbie"
[SIZE="I own a kontiki 665 and wonder if anyone can tell me if there is a way to fit a skirt without using those press stud things.5"][/SIZE]:shout:
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Velcro strips or 'C' rail sections possibly, if you want to stop draughts or keep dogs inside a privacy you could also use windbreaks
Peter
1,622
280
Five Roads Alyth
A class RV
since 2005
Same as you we wanted a skirt, for draughts, and didn't like the press stud idea.
As Peter says, C section channel, or awning channel, is ideal. I was able to instal it under the side so it isn't particuarly visable. As for the skirt, easy, you can get a couple of different heights and buy it at the lenght you want and it's pre made with the awning bead, really doesn't get any easier in my book.
The bits can be got at most decent Caravan/Motorhome stores and lenghts up to 3 meters are normal for the C channel and if you need more look about for longer.
The place we bought from had an excellent tip for the wheel arch. Get a lenght of the plastic figure of eight, usually come in one meter ish lenghts and cheap as chips and cut to the gap in the C channels either side of the wheen arch and use a section of the skirt inverted to cover the wheel arch. I conceeded defeat here and used three press studs around the arch, but overall looks tidy and means I haven't got heards of the 'orrible buggers down the side of Winne:thumb:
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
you could always have put the press studs on the wheel side of the wheel arch that way they wont be seen at all from the outside and if you use that flexible white plastic awning channel on the bottom of the side of the van there will be virtually nothing seen at all:thumb:
1,622
280
Five Roads Alyth
A class RV
since 2005
There a good idea too, mind you on Winne the last press stud may be difficult(skin removing) as it's a bit tight in the wheel arch:thumb:
