Knaus Sky Ti Kitchen Tap Malfunction
Discussion in 'Tech/Mech General' started by BFM14, May 18, 2016.
  1. BFM14
    BFM14 Funster
    Jan 24, 2015
    84
    94
    Leicester
    on a campsite in Italy and when wife went to use the kitchen tap the water did not flow; hot or cold. Turned the bathroom tap on and water flowed in both kitchen and bathroom. I forgot to bring the manuals for the Mhome but am led to believe that the water pump is controlled by a micro switch at the taps.
    If this is true can I replace just the micro switch in the tap assembly or do I need to purchase a complete new tap?
    Does anybody know how I could get the correct bits here in Italy?
  2. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    3,093
    2,951
    Essex
    I bought my microswitch on ebay, you might need to know which switch.
  3. BFM14
    BFM14 Funster
    Jan 24, 2015
    84
    94
    Leicester
    Thanks I need to know what tap is fitted. I haven't got manuals with me so will be looking at Cak website to identify it
  4. scotjimland
    Jul 25, 2007
    28,939
    25,628
  5. BFM14
    BFM14 Funster
    Jan 24, 2015
    84
    94
    Leicester
    Thank you @scotjimland. Took the first part oif the tap off to find that the brown wire has come away from where it was located. When I have built up the courage will go to the next stage and dismantle the tap and see if I can reconnect the wire. Thank you for the attachment.
    • Thanks Thanks x 1
  6. Fletton
    Fletton Funster
    Oct 19, 2014
    712
    2,688
    Nth East Lincs
  7. Kensmith314
    Kensmith314 Read Only Funster
    Mar 18, 2015
    40
    51
    Shropshire
    I also have a Knaus Sky Ti and this very same thing happened to mine.
    I had a very good independent engineer come out to fit a new microswitch and I watched him do the job.
    Unfortunately, the switch seemed to be glued in and, try as he might, he couldn't get it out.
    Instead, he did a bodge job by soldering the stray wire back on - it is still perfectly good almost a year later.
