1. Our Classifieds are free to subscribers
    For help in listing an item or for marking it SOLD please see this help file
    PLEASE EXCERCISE DUE DILIGENCE BEFORE PARTING WITH MONEY
    MotorhomeFun cannot vouch for the honesty of members.
    PLEASE DO NOT BUMP 'FOR SALE" THREADS or they will be removed.
FOR SALE Kippor Genny
Discussion in 'General Classifieds' started by Pam, Apr 14, 2015.
  1. Pam
    Pam Funster
    Jul 3, 2012
    82
    60
    Essex
    Can take to Peterborough
    Not sure if this is allowed so if not please take down or I will check back soon and remove it , I've tried to find rules but can't find them , anyway were see you at Peterborough , we bought a KIPOR generator and have never used it were selling it paid £470 for it selling for £350 . KIPOR IG 2000 230V PETEROL GENERATOR THIS SUPERSEEDS THE 2000TI MODEL PURE SIGNWAVE PETROL GENERATOR PLEASE NOTE THAT THIS AND ALL THE OTHER KIPOR IG RANGE OF GENNIES ARE SUITABLE TO RUN COMPUTER EQUIPMENT 230 VOLT 3 HOUR RUNNING TIME ON A TANK OF FUEL FOUR STROKE PETROL ENGINE A VERY LOW NOISE LEVEL OF ONLY 61~73dB 22.0 KG IN WEIGHT Rated frequency (Hz) 50 60 Rated voltage(V) 230 120/240 Rated current (A) 7 13.3/6.7 Rated speed(r/min) 4500 Rated output (kVA) 1.6 Max. output (kVA) 2.0 DC output 12V-8.3A Phase number Single Current circuit breaker Without Structural type Portable Fuel capacity(L) 3.7 Set fuel consumption(g/kW.h) 550 Continuous running time (hr) (rated output) 3.5 Noise level (zero load--full load) dB (A)/7m 54-59 Overall dimension(L×W×H)(mm) 520×300×425(genset) Net weight(kg) 22 Starting system Recoil starter Fuel type Automotive unlead gasoline Lube oil type SAE10W30 (above CC grade) Engine model special for digital generator Engine type Single cylinder, 4-stroke, OHC, gasoline engine Bore X Stroke 58X40 Displacement(ml) 105.6 Compression ratio 8.5 Rated power[kW(Hp)/(r/min) 2.2/4500 Ignition system T.C.I Spark plug A7RTC/UR5 Lowest fuel consumption(g/kW.h) 420 image.jpg
