If it is sneezing, it sounds like the timing is out. Its sending the combustion back through the carb.
It can happen over time.
All engines are made from some kind of metal, they are not made from flesh and blood so therfore do not become adicted to anything.Slightly off-topic.
Our jetski always needs a dose of carb-cleaner up the air-intake to get it going.........does this mean it's hooked on the substance!!:Angry:
BW
PS Yes - I know jetskis are about as popular as gennies too
possible but very unlikely.
how can the timing alter if it hasnt been run?
im assuming it started and ran ok last time it was used but it has now been stood idle for a few months.
There has always been a misconception that motors become adicted to easystart etc, the reason that you have to use dope to start an engine is becouse somthing else is wrong with it.
Usualy diesels that need easystart are worn out,no compression or the glow plugs are burnt out.
Petrol engines that need it are usualy worn out, damp, or stale petrol.
Have a good look around,,
You may find a dealer that will give you a bit of part X against a "Honda"
Yes,not only do I remember them, I owned a few.Mmmmm!, you don't remember Mk 1 transits then.:Sad:
Been at it for about half an hour, took spark plug out, quick clean ( was black, with like soot over it ) bit of fresh petrol down the port, screw the spark plug back in, couple of pulls and TA DA IT STARTED.
