Keeping an old vehicle going
Discussion in 'The Beginner' started by Schpinky, Jul 11, 2013.
  1. Schpinky
    Schpinky Read Only Funster
    Aug 16, 2012
    9
    Ringwood
    Hi all, only recently registered with Motorhome fun and hope I am posting in the correct place. Sorry if not and can you point me in the right direction. :Smile:
    I have a G reg Citroen Hymer 564 and have spent a lot of money on it over the last few years getting many major parts reconditioned. The starter motor is causing a real headache. I have had the starter reconditioned five times in as many years and it is still not right.
    Does anyone know where I might find a new or decent starter motor for my beloved old Hymer?
    Thanks for reading this, I really hope someone can help.
    Schpinky
  2. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,557
    7,064
    Plymouth
    I with you on the older MOTORHOMES but it may help if the engine type were known 2.5 1.9?? Petrol / Diesel
    I had a similar problem with last Ford Transit after 4 went back to local reconditioning shop well known in Plymouth ,turned out the bendix didn’t match the teeth on the flywheel .
    Searched around on eBay and found supplier with a contact number after the usual questions bought one correct for my model and cheaper than shop locally job done
  3. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,855
    roche cornwall
    as to the starter is the flywheel ok .they had a habit of chewing up the ring gear on them . that can mess a starter up.
  4. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    I agree with Alan, If you are chewing starters, look for other reasons! As already suggested, flywheel may be worn.
  5. Xabia
    Xabia Funster
    Jan 20, 2011
    727
    428
    Rural Nottinghamshire and Spain
  6. Schpinky
    Aug 16, 2012
    9
    Ringwood
    Thanks peeps, the more info the better
    Thank you all. Yes, I should have included more info. It's a 2.5L Turbo Diesel. I shall amend the original post to include that info. All the information you have given is great and I will investigate further. Feel like I may be starting to get somewhere and so soon after posting! Great stuff.:thumb:
    • Like Like x 1
  7. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,180
    16,644
    Liverpool.
    A little more info on what is actually happening to the starter will help. Is it engaging ?. Is it just clicking ?. Is it throwing out before starting ?. Is it chewing up the bendix ?. etc, etc, etc,.
  8. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    Also, check if the starter needs shimming. Modern engine starters just bolt on, but older models might require shimming to get the correct teeth engagement, a skill not understood by many fitters used to modern vehicles.
  9. John & Joan
    John & Joan Funster
    Mar 30, 2010
    1,243
    671
    Full Time on the road
    Back in the 70s I had a Cortina with starter problems. We tried everything new ring gear pinions with different teeth etc.
    I had one starter on the vehicle, one in the boot, and one in the auto electricians getting new pinion fitted. I was such a regular customer they fitted them free and I got the pinions at trade price.
    Then one day the engine blew up and I fitted another and the same ring gear and starter were fitted and it never needed another starter again. It turned out that the face on the crankshaft had been badly machined so everything was running out of true.
    We bought the car from a dealer as scrap, as they couldn't fathom out the problem either. I had the art of changing the starter off to a matter of minutes.
