keeping a starter battery topped over winter help
Discussion in 'Solar Power' started by Peter & Elaine, Oct 12, 2014.
  1. Peter & Elaine
    Peter & Elaine Funster
    Aug 30, 2012
    4,019
    6,543
    Roobarb land
    We may have a issue this winter with our van going into storage for about 2 months or so
    So I have a question for our electrical bods
    I have fitted 280 watt soler panels though a 30 amp controler
    If I run a fused wire at both ends from hab battery's to starter battery's with a large say 30 amp diode in line so power can only go in one direction And prevent reverse flow from starter battery
    Will it keep my starter battery topped up
    It seems to me that it will be such a easy fix so what am I missing (n)
    Be gentle :)
  2. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,230
    3,637
    walthamstow east london
    yes that would work you probably dont need the diode if you know where the split charge relay is on your van you can just bridge the terminals with a short wire incorperating a fuse the fuse should be rated low enough to blow if you attempt to start the van as you dont want to subject the leisure batteries and wiring to starter currents if you wanted this can be done as a permenant fixture and for ease of use incorperate a switch or just have the fuse in a place you can remove it easily ,normally its the relay terminal s 30 to 87 that need linking on a standard relay
    • Like it Like it x 1
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    As above.....either way but do ensure you use a fuse. (y)
  4. Mikeco
    Mikeco Funster
    Sep 26, 2013
    737
    546
    Market Rasen
    When I left the van for 4 months parked up at home I connected the vehicle battery to the leisure battery with a cable with a fuse at both ends. The solar panel kept both charged up okay.
    Mike
  5. Peter_n_Margaret
    Peter_n_Margaret Read Only Funster
    Oct 27, 2013
    87
    62
    Adelaide, Australia
    I leave the Iveco we are using in Europe parked under cover in Germany for 6 months over winter.
    No starting problems at all after that time provided the terminals are disconnected to ensure there are absolutely no loads.
  6. musson
    musson Funster
    Dec 25, 2013
    409
    143
    grantham
    It might be easier to fit Dual regulator then you can set the outputs required for each battery,i had one one my first MH and it worked ok, this van works through the sargent system charges one for 4 hours then flicks onto the other.
    Paul
  7. hilldweller
    Dec 5, 2008
    27,554
    26,665
    Macclesfield
  8. g8ysn
    g8ysn Funster
    Jun 5, 2012
    585
    404
    ng219ep
    i charge my van battery via a trickle charger[ halford,s] plugged into inverter just been to look at charge display on green [fully charged] now probably charging 3+ 120 amp battery bank ,seem,s ok but if really cold [no sun] will put on ehu, natural drainage plus extra safety features,tracker/alarm,s etc
