Kawasaki GA 1000 Generator
Discussion in 'Tech/Mech General' started by errpaul, Sep 25, 2009.
  1. errpaul
    errpaul Funster
    Feb 27, 2009
    499
    51
    Wiltshire
    :Confused:Ok, so I need a gennie for use at Disney.
    We have a very small budget for this and so initially looked at cheap 2 stroke ones, which are generally around £80 brand new.
    I have started looking at 2nd hand ones and have come across the Kawasaki which although above £80 is still relatively cheap.
    We only really need it to charge up the leisure battery, and to charge the odd electrical device so the digital inverters etc are not needed (I don't think).
    Does anyone have the Kawasaki?
    Is it any good?
    Is it better to get a new 2 stroke, or a used 4 stroke such as the Kawasaki?
    :thanks:
  2. geoff587
    geoff587 Read Only Funster
    Feb 13, 2009
    675
    Doncaster
    hardhatIncoming " Generators"
  3. hilldweller
    Dec 5, 2008
    26,858
    25,725
    Macclesfield
    There is a problem with generators, electrical spikes, if your luck is out these can blow your charger or laptop. The safest types are Sine Wave generators which have electronic regulated outputs.
    We have this:
    PowerLand
    Not used it much but it did the job. How long will it last ? Who knows but it's all I wanted to pay for the odd power boost. It was just over £200 when I bought it last year.
  4. errpaul
    errpaul Funster
    Feb 27, 2009
    499
    51
    Wiltshire
    Would a surge protector extension used in the van prevent this?
  5. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,126
    13,861
    Heavan
    Not in this case as its in winter, and in |France. a required item :thumb:
    Although Bryan is right as he normally is with anything electrical, I would say that it can happen but rarely does. The answer is to do what I have done and rig your van to be totally 12v sufficient. I therefore run all my stuff through 12v sockets, tv, laptop etc. You can of sourse then use a sine inverter to use your products as well or just buy a 12v laptop charger. The only non 12v item we have is the sky box which runs through and invertor. SO in answer any generator will do its just a case of how much or little you want in terms of reliabilty and or upsetting your neighbours.
    Our Honda is whisper quiet and economical but expensive even used. If its only for a week and its not something your going to use to often why not go for a cheep one and see how you get one first?
  6. hilldweller
    Dec 5, 2008
    26,858
    25,725
    Macclesfield
    They aren't up to much, I wouldn't rely on one. But it's in the hands of the gods if you have any problems at all.
  7. hilldweller
    Dec 5, 2008
    26,858
    25,725
    Macclesfield
    Not quite. Unless you isolate your leisure battery for charging then your genny is going to power a pretty expensive on board charger.
    I have little of experience gennies, I've just picked up the odd disaster story on the forums, but I do know that if it says Sine Wave then you have a lump of electronics between the spikes and the alternator. I guess you also have more to go wrong.
    Can't argue with Buy Honda - though strangely enough the one time my Honda bike let me down was just before Morecambe when the charge regulator failed, a common fault on that bike but I thought mine had got away with it.
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,681
    17,298
    YO11 2BD
    unless its an open frame builders genny, a four stroke will always be quieter than a two stroke when under load and more fuel efficient.:thumb:
    if using a non digital invertor genny ensure you start it and let it run for a few minutes to 'settle down' before plugging in/turning on your charger.
    i reckon most overvoltage problems occur, in a non invertor genny, when the engine is just started and revs irraticly (sp) until warm.
    usually voltage is controlled by revs unlike an invertor type which isnt rev critical.
    most invertor types have a constant voltage output (12v nominal at the genny converted to 230v at the outlet socket) regardless of revs and a 'smart' throttle which means it will practicaly be on tickover with a very light amps load and will increase engine power output automaticaly as the load amps increase making it very economical.
  9. geoff587
    Feb 13, 2009
    675
    Doncaster
  10. haganap
    Dec 5, 2007
    11,126
    13,861
    Heavan
    it was in loud print to show others the error of their ways before the incoming :Rofl1:
    No excuses then,
    I like that though, a closed season for the anti generator brigade:Rofl1:
  11. errpaul
    errpaul Funster
    Feb 27, 2009
    499
    51
    Wiltshire
    Should look into creating a close season....a great idea :Rofl1:
  12. errpaul
    errpaul Funster
    Feb 27, 2009
    499
    51
    Wiltshire
    Right, so I've just won the bidding on this gennie on ebay:thumb:
    So if anyone thinks it's rubbish please don't tell me now as it's too late. Hope it's a good un:Wink:
