Thanks, we bought one but have had to take it back because our height is 245cm and they start at 250cm and it just didn't fit properly, it makes a big difference 5cm, very disappointed that we can't get one. Hopefully they will bring one out that is lower, fingers crossed lol
We have one.. but ours is an older model.
2 things to consider...
Height .. as mentioned above. The reccomended heights are to the awning rail .. not of the van
Your awning rail... if it sticks out from your van you may struggle to get a good tight fit against the side of the van. My understanding is that this has improved with the newer models... also be sure to get the rear upright pole set if it doesn't come as standard. .. great addition.
It's an awesome awning.. we use ours mainly for our dogs and some storage .. but it's strong.. fast to erect and dismantle and we have found it stands up to strong winds very well .. (storm straps required)
We have just brought a new Kampa Pro 330L, its still in the box, do we need the upright support poles that go next to the van? until a hail and wind storm we had the Kampa Motor Rally Club 260L ( very flimsy for Beni) which included the upright poles but not the fibre poles! that help keep the roof in shape, they were an extra, a bit of a con, the only extra that we have brought now are the set of eight suckers to attach to the sides to the van.
A very good tip that that someone recently suggested, spray the awning rail with Slick or a similar non greasy lube, it aids threading the awning onto the rail
PS we still have the the old 260l complete with the small roof tears, if anybody needs it. no charge
On the Fiamma rail of our previous van, it did cause it to stand off the van sides. We filled the gap with 2 'noodle' swimming aids, foam tubes, ÂŁ1 each from Poundland. The new van has a Thule awning, the slot in the rail is more underneath and sits closer to the van.
Very happy with the 260L, stood up to some nasty weather last year. If I'm fitting it myself, I tend to take the side doors off, less weight and easier to manage when winding the awning back up.
The Kampa Motor Rally is a good awning and comes with both 4mm and 6mm beads fitted but is too high for our van and are now only made in the Air version so expensive. Instead we bought the Kampa Rally 260 which are made for caravans but fit our van at 2.35m high, this comes with the 6mm bead only but I pulled out the 6mm and pushed in a 4mm which now fits our Fiamma awning.
Using it on Jims site at the moment.
