We have a problem with a Kampa awning that we recently purchased and just wondered what experience others on the forum have had with these awnings.
The awning is the Kampa Motor Rally Air Pro 330, highly recommended on here and in all but one aspect we are pleased with the awning. The problem is the Centre Beam which collapses with just a small amount of downward pressure or breezy conditions (15k of wind).
We have used it twice now and on both occasions this centre beam seems to be it achilles heel. Initially Kampa said we weren’t putting enough pressure in the beams and that we needed to pad the gap between the awning and the body of the Motorhome.
Well on our second outing we got around 10psi into the awning (recommended 8-11psi) and we padded the centre beam with rubber blocks (sold as an extra for this purpose).
There wasn’t much wind around at the time but the slightest amount of downward pressure would pull the centre beam down ever so easily (see pic).
Kampa now want us to up the pressure to around 13psi (they are tested to 22psi) and to put blocks on the end beams as well even though the end beams are rock solid and don’t suffer as the centre one.
Anyway we will try all this in the hope we get there in the end, but I’m not hopeful.
Does anybody have this particular 330 Motorhome Awning.
I know the 260 is popular, but the centre beam on these is much closer to the end beams, ie: more stable.
What experience do others have.
