Kamikaze insects
Discussion in 'The Beginner' started by Wikisnoodle, Jun 13, 2010.
  1. Wikisnoodle
    Wikisnoodle Read Only Funster
    May 9, 2010
    11
    Worcestershire
    I've just spent, what felt like forever, getting all the kamikazi flies off the front of my van following a trip to Chester. As usual, most of them were on the most-difficult-to-get-at overcab bulge (Autotrail Cheyenne 635). 3 weeks from now, I'll be off to Cornwall and the whole procedure will, no doubt, have to be repeated on arrival, 3 or 4 times whilst there and again on our return.
    Currently I'm up and down a ladder with a bucket of warm water/zipwax and a soft brush on a pole, scrubbing the stubborn ones off with a toothbrush. Would a jetwasher be a good investment? Has anyone found any better solutions (other than "try travelling in the winter instead!").
  2. movan
    movan Funster Life Member
    Dec 2, 2009
    13,199
    23,696
    Moving around
    Bit extreme but someone once posted they were so fed up with this problem they put cling film over the bulgey bit and then just had to take it off with flies and all.... depends how desperate yu are I guess.
    Someone else said to soak a towel in fairy liquid in water and leave it flat out on the bulge to soak in... Then remove the towel and the flies come away. Don't know if it works.
    I've always had to resort to elbow grease and still leave some of the little blighters behind.. (Got some of that waterfree cleaner at the last show and that doesn't work either).:Sad:
  3. Ralph-n-Bev
    Ralph-n-Bev Funster
    Nov 30, 2009
    5,941
    9,044
    Wrenthorpe, Wakefield.
    Ours got covered in the orange squashed variety on the way back from Druiridge Bay Northumberland , a couple of weeks ago. Because of all the hot weather they got baked on.
    Ralph still hadn't managed to get them all off before our trip to the I.O.W where we collected more, this time of the black squashed variety!
    These got baked on even more, along with the remaining orange ones , with the red hot weather we had.
    Once home he spent ages up the step ladders with a soft brush and various car and MH cleaners.
    Eventually fairy liquid and hot water saved the day.
    There must be something on the market specifically for removing bugs.
    Our luton has windows to the 3 sides so we dont really want to use the jet washer on it.
    Bev
  4. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Don't have the same problem now low profile, but found a wet towel laid across and kept damp with a hose for a while prior to cleaning often did the trick, on previous vans.
    Would not resort to power washer have seen the damage they have caused to sealing etc.
    Dave :thumb::thumb:
  5. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    Dropped on this by accident -2 caps of bio washing liquid mixed with about a pint of bleach then water into a gallon garden pressure spray -spray onto front of van, rub with a soft extending brush, rinse off with hose :thumb: move onto 1 side and repeat :thumb: about 20 mins to do all the van :thumb: also removes black streaks :Rofl1:
    terry
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,321
    YO11 2BD
    you wouldnt be an ex-tugger would you ?
    you see them on all the sites washing their caravans :Doh:
    do you wash your car to get the bugs off when you get to the supermarket ?????
    just leave it 'til you get home and do it once :thumb:
  7. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,327
    34,801
    I've used those "magic sponge erasers" in the past. Now use Onedrywash as for the rest of the van. Takes a bit of rubbing but no worse than getting rid of black streaks.
    Graham
  8. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    Defiantly in your camp John :thumb: only wash it before we go :Rofl1: if it was left to me it would not get that :thumb: but all I want is a peaceful life :Eeek: if you get my drift :thumb::Rofl1:
    terry
  9. pappajohn
    Aug 26, 2007
    29,704
    17,321
    YO11 2BD
    yep!!!
    set off for two weeks in spain with a white van.....came back with a white van with a red front.
    i was on hols and wasnt wasting time cleaning bugs off. :thumb:
  10. lookback
    lookback Read Only Funster
    Nov 30, 2007
    142
    25
    Mareham le fen, Lincs
    I found that using a piece of cloth - mosquito netting - is great for getting the dead flies etc off the front of the MH with minimum of effort.
    Ian
  11. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,534
    5,620
    Near Mold North Wales
    Surely the most logical answer is don't go to Chester. :Smile:
    Phil
    I'll get my coat .......:Tongue1:
  12. Smoogy
    Smoogy Read Only Funster
    Mar 29, 2010
    9
    Porlock, Somerset
    Although I think your cleaning tendencies might be touching on the excessive, I shall indulge you in my secrets...,
    firstly, I wouldn't use a jet-wash on anything that resembles plastic as our motorhome manufacturers spend all their time trying to keep the water out, (water under pressure can be used as a cutting tool).
    So we should look to our motorcycling friends who have spent more time removing these 'spot welded' fiends from their visors, teeth & eyeballs! :Rofl1:
    The liquid you're looking for is the aptly named product 'Bug Off ' but as the old boys will tell you the best trick in the book is to get a paper towel immerse it in warm water and leave on van to soak for 5-10 minutes. This will magically lift the bugs off, the only problem with this is that the front of the van will end up looking like an ogre's shaving accident so a good adaptation is to use an old bed sheet, one with high cotton content to absorb water and remain flat to the unit.
    Hope this helps
  13. 1_man_and_his_dob(lo)
    1_man_and_his_dob(lo) Funster
    Feb 4, 2010
    2,258
    1,518
    Mid. Glamorgan, S. Wales
    I find that buying a van in dark-blue seems to work.
    Doesn't stop them splattering the front....you just can't see it as much. :BigGrin:
  14. movan
    Dec 2, 2009
    13,199
    23,696
    Moving around
    :Rofl1::Rofl1::Rofl1:
  15. GregM
    GregM Read Only Funster
    Nov 2, 2009
    255
    Nottinghamshire
    Oh, are you meant to wash the flies off, I thought they were used to record/show off how many miles you have driven in your motorhome. Please don't tell Tracey that's not the case.
  16. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,534
    5,620
    Like it - never thought of that option.:Laughing::Laughing:
    Phil
  17. Wikisnoodle
    May 9, 2010
    11
    Worcestershire
    Thanks to all responders. No, I'm not an ex-tugger – it's just one of those laws that says, on pitching, my van will always have more of the horrors than anybody else's!
    I'd go for the idea of seeing how many I could collect, but I don't think my clean freak co-traveller would fall for that one. :Smile: so wet bedsheet it is then!
  18. Euromobil
    Euromobil Read Only Funster
    Jun 23, 2009
    76
    hampshire
    Try your local "poundstretcher" they do a £1 trigger spray of Tar/Insect remover. Spray on, leave for a few mins just rinse off, sounds too good to be true but it really works , gets rid of black streaks as well.
