Jumper starter
Discussion in 'Tech/Mech General' started by nomadic, Oct 25, 2012.
  1. nomadic
    nomadic Funster
    Sep 27, 2007
    673
    179
    Shropshire based
    Information request please,
    As our motor home is/has been in storage for some time, with no access to EHU, the engine battery is loosing its charge. The solar panels are keeping the leisure batteries well topped up, but the trickle charge to the engine is now insufficient.
    My thoughts are to invest in a jumper charger, complete with compressor, battery charger, etc. which is on offer until the 30 October, at Maplins.
    It has a 400amp crank strength, and is apparently strong enough to start a “car, boat or motor home” but does not state the size of engine, ours is a 2.7 merc, diesel.
    Can anyone please confirm if the 400amp crank is strong enough, or do we need to consider a larger amperage ?
    Thanking all in anticipation.
  2. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,537
    5,621
    Near Mold North Wales
    These are the details of my battery: (2.2 Peugeot)
    Hope that helps.
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,266
    5,253
    East Sussex 01-580-881288
    Yes it should be OK, best to start the engine every couple of weeks and slightly move the van by a couple of feet to put the tyres in a different postion
    Peter
  4. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,855
    roche cornwall
    why not rig up a jump lead set up off the leisure batteries . ideally with a big red plastic key switch . this could be used for jumping or even charging off the solar power .
    not much cost and if the liesure batteries are full easy work for the solar panels .
    mymate uses a 12v to 24 v battery to battery in the circumstances you quote . if it was 12v to 12v .it would have been so easy . your is so its ideal.
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,323
    YO11 2BD
    it will be if the engine's a good cold starter.
    you do need to recharge the 'booster' on a regular basis, in winter especially.
    mine booster got neglected and the battery only lasted one winter season.
    it's one of those items that's rarely used, chucked in the boot or garage and forgotten about until needed and flat.
    when i took it apart it had a 17ah motorbike battery.
    binned it and now use proper 600amp rated jumper cables if needed.
  6. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,756
    3,256
    Eastbourne East Sussex
    As pappajohn says, they do need to be kept charged up as they are lead/acid (sealed) batteries.
    I keep mine in the boot of my car, plugged in to the 12v socket there, which is ignition controlled so gets a charge every time I use the car. The jump start is new so I cannot say whether this is a good idea but it works for my rechargeable torch which is years old and still going strong.
  7. pudseykeith
    pudseykeith Read Only Funster
    Nov 5, 2007
    382
    105
    Leeds West Riding of York
    A point to remember is if you relie on a boostr battery and the leave the vehicle battery to discharge and stay flat for long periods the acid in the battery will return to water and leave the battery US.
    PK
