Judder/base
Discussion in 'Motorhome Chat' started by sue1959, Jun 10, 2010.
  1. sue1959
    sue1959 Read Only Funster
    Feb 11, 2010
    1,390
    626
    Ireland
    Just outof curiosity is it only Fiat that has the judder? Also does it have to be rectified or can it be lived with?
    We most likely won't by Fiat as you don't see many here.
    Also if something is a Ford base does that mean it has a Ford engine eetc?
  2. hilldweller
    Dec 5, 2008
    27,240
    26,241
    Macclesfield
    I think it's a Fiat speciality.
    There are reported cases of the judder so bad the gearbox has broken, so if you detect any it's not going to improve so does indeed need fixing.
    I thought the majority of MHs were built on Fiat, so surprising you don't see many.
  3. sue1959
    Feb 11, 2010
    1,390
    626
    Ireland
    Sorry Brian I meant that there aren't many fiat dealers here, near me anyway and you see very few fiat cars. I was just thinking if the MH needs spares it might be better to go with another base.
  4. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    My fiat doesn't judder at all and if it did I would get the engine and gearbox mountings looked at.
  5. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    The Fiat built engine is found in many manufactures vehicles, the seval group includes Peugeot and Citroen, talbot etc so who gets a fiat engine not sure but itis a fact the some of them do. fords Have a Ford engine and Mercedes their own but anyone else who knows. The problem is not actually with the engine, it is a combination of gearbox ratios and engine mounts, resulting utimately in Clutch and engine mount problems. Further gearbox problems were caused by the scuttle leaking on most of the seval models allowing water to build up on an ingress into the gearbox causing premature failure of some gears.
  6. mejulie
    mejulie Read Only Funster
    May 22, 2010
    167
    Caversham,Reading
    I have a Fiat and there is no judder or anything else wrong for that matter.
  7. ddavewoods
    ddavewoods Read Only Funster
    Jan 9, 2010
    109
    South West
    My 07 plate Ducato 160 based Swift doesn't suffer from reverse judder, but it did until today suffer from a build up of water around the injectors as the water entered into the air intakes on the bonnet and leaked through the air scuttle and sat in the top of the engine, this was rectified today by the fitting of a plastic engine cover even though the vehicle was out of warranty at a cost to Fiat of £200.89.
  8. david price
    david price Read Only Funster
    Sep 28, 2008
    387
    27
    Bridgenorth
    I did have the judder and the clutch went after 9000 miles and under 2 years old.Fiat paid part but still cost me over£700.No problems now but i will never buy fiat again because thier warranty is not worth the paper it is written on.
    Dave
