Jerking when setting off
Discussion in 'Fiat' started by Vennwood, Aug 20, 2015.
  1. Vennwood
    Vennwood Read Only Funster
    Nov 15, 2007
    68
    28
    Devon
    When we pull away from lights or junction the camper jerks quite badly until we get going. It feels like the accelerator return spring (if there is one) is missing. Also when idling the engine RPM starts to creep up from 750 to 1500. All the local Fiat dealers are fully booked next week and we leave for France at the end of next week. The engine is the Fiat 3.0 ltr and its a 2009 model any suggestions would be very helpful
  2. Mel
    Mel Funster
    Oct 6, 2012
    2,103
    2,114
    De Haan Belgium
    Manual or cofortmatic?
  3. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,801
    10,971
    Glasgow
    Our AT does that too when engine is cold
  4. Vennwood
    Nov 15, 2007
    68
    28
    Devon
    Manual
  5. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,135
    15,070
    Leeds the one up North
    I've never experienced that with my 3 litre and the rpm is 800 at tick over whether hot or cold
  6. Vennwood
    Nov 15, 2007
    68
    28
    Devon
    It was fine until a couple of days ago and while we haven't owned it long it has been fine. Full service history. Just a B***er this is happening just before we set off.
  7. Techno
    Jul 28, 2010
    14,135
    15,070
    And you haven't got a check engine warning?
    IMHO it sounds as though the throttle valve is not closing fully.
  8. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    do you really need a Fiat garage to diagnosis this..look around locally for recommended commercial garage..
    • Like Like x 1
  9. Techno
    Jul 28, 2010
    14,135
    15,070
    Peugeot or Citroen garage will do the same job. EDIT or even IVECO seeing as it is their engine
    • Like Like x 1
  10. Vennwood
    Nov 15, 2007
    68
    28
    Devon
    Thanks Andy I'll check around - never thought of that
  11. Judge Mental
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    I just googled and there are loads including Iveco which would be my first call if Fiat/Peugeot/ Citroen busy. would try and find someone good outside the expensive franchised set ups..loads of reputable mechanics around.
    • Like Like x 1
  12. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,752
    11,954
    Plympton, Devon
    The jerking might be engine mounts and the tickover issue unrelated. Not sure that help!
  13. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,568
    3,375
    Telford, Shropshire
    Not sure about the jerking on take off but the idle speed issue could be down to a faulty alternator.
    D.
    • Like Like x 2
  14. Chris
    Chris Funster Life Member
    May 5, 2010
    16,624
    35,951
    kent
    I seriously misread the title to this thread.
    I thought "setting" read " getting"
    :D
    • Like Like x 7
  15. Mousy
    Mousy Funster Life Member
    Sep 13, 2013
    2,152
    7,323
    Sa15 2DG
    Great minds think alike! I almost choked on my mouthful of spaghetti Bol.
    Opened the thread in great excitement only to find technical questions like manual or auto:eek::rofl:
    • Like Like x 7
  16. Vennwood
    Nov 15, 2007
    68
    28
    Devon
    I thought that only a Fiat dealer would have the "magic box" that would connect and instantly tell you what the problem was.
    To go back to something Andy mentioned. I did have an amber engine warning light on when I picked up the camper but the dealer said it was "due to the engine battery going flat while it stood on the forecourt and that had been reset" To be fair I haven't had the problem since.
  17. Vennwood
    Nov 15, 2007
    68
    28
    Devon
    Thanks Dave,
    I'll bear that in mind if I can get it booked in and mention it. What would cause that? - The camper has a B2B fitted and looking through the previous owners service history this vehicle has a history of "flat engine battery" The selling dealer had to "clear the fault log as there were 7 instances of low engine battery" Again looking through the records it has had 2 replacement engine batteries in the past 5 years - odd don't you think?
  18. Judge Mental
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    Yes...points to wot Dave said:)
    Any auto electrician could varify.....
  19. Vennwood
    Nov 15, 2007
    68
    28
    Devon
    You would think so but the records show it has been into several Fiat dealers and Hymer dealers with this problem but none have identified the problem as a faulty alternator. I'm thinking that Dave may have hit on something the others have missed.
    • Like Like x 1
  20. dave newell lvs
    Oct 31, 2008
    2,568
    3,375
    Telford, Shropshire
    It is feasible that the B2B is causing the revs rising issue. The alternator output is regulated via the engine ECU, if it sees a lower than expected voltage at the alternator output it will increase rpm to compensate. The B2B works by fooling the alternator to produce more current, it does this by artificially putting more load on the alternator. If the engine battery is lowish, say 50% charged, then the additional load of the B2B may just cause the voltage at the alternator output to be lower than the ECU wants to see so it raises the rpm. Try removing the B2B fuse from the engine battery to rule it out.
    D.
    • Like Like x 1
