I've set the heating at 30° but... (2 Viewers)
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
surely there is another way to safely empty my Gaslow cylinder so I can transfer the system to a new van?
Sidney
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
There is only one valve that can be closed on the bottle (and that's on the feed to the regulator).
But the filler line (full of LPG) goes straight to the bottle, there is no valve. Undo the filler on the Gaslow system and you get a lot of LPG pretty quick.
funflair
19,344
30,223
Guisborough
MORELO palace
since 2012
I could be even more sensible and say" Why didn't you just close the valve" Would that be good advice coming from a female?:pray:
It all sounds good to me, just waiting for somebody that knows something I dont.
Martin
funflair
19,344
30,223
Guisborough
MORELO palace
since 2012
I thought there would be a non return valve in there.
Martin
TheBig1
17,630
43,269
there is a non return valve on the input
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
As others have said there is a non return valve fitted to the inlet inside the bottle,, so just break the joint on the refill hose and let the gas is the hose dissipate , then fully unscrew the hose and the regulator hose :)
Mar 23, 2012
9,545
32,085
sleights
c class
If its like the gasit the non return valve only operates when there is a significant flow out be prepared for quite a loss of gas until it operates definately wear gauntlets as some very cold gas will escape and avoid naked flames!!!!
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Twice in the last couple of months had cause to undo the filler pipe going to our Alugas system
First time was to replace the little flappy cap thing, and the second time to change it to a twin bottle system
Absolutely sweet fanny adams came out either time !
Charlie
3,211
3,639
Auto Sleeper Kemerton.
Im a newbie
I actually know a woman called Fanny Adams... she's married to a bloke called Richard.. it's true honest !
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
It'll just be the liquid in the filler pipe escaping.
A little liquid makes a lot of gas!
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
I do not know about other systems but there is not a non-return valve in the actual filler of our Alugas system.. Only in the bottles
The minor downside is that when you fill up you actually loose a whole pipe full of gas ! ( so not a lot to say the least :) )
And of course should work have to be done on the system that pipe is completely empty
Sep 28, 2015
2,017
2,613
Kingston upon Hull, East Yorkshire.
Hymer B544
2001 Caravans 2011 Motorhomes
There should be a non return valve in the filler point so you should end up with gas trapped in the pipe between the filler point and the bottle. This will be what's escaping when you release the nut at the top.
Filler point valves can sometimes stick open.
Sidney
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
I had dropped Gaslow a line before posting on Fun.
I received a reply this afternoon...
"Thank you for your enquiry, there is a non-return valve in both the cylinder and the filler valve so you can disconnect the cylinder without fear of a gas leak – you may find there is still liquid gas in the filler hose but this is nothing to worry about."
I didn't think it through... If the filler was damaged in a RTA there would be a fireball without a non return valve :whistle:
denisejoe
5,617
12,051
Warden isle of sheppy
Since 2004
When you undo the pipes there will be a hell of a lot of gas coming out. If you just crack the pipe a little it will take ages to finally clear.
Joe
Lenny HB
53,421
149,953
On the coast in West Sussex
Hymer B678 DL
Me thinks it's about time you replaced your inlet. Sounds very dangerous filling pressure is around 140psi and easy to get frost burn when disconnecting the pump.
Has it definitely not got one or has it failed, I've never seen a system without one.
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
As far as I am aware it never has had one.. and if I aint had frost burn after 7 years I doubt I will get it now ! :)
Of course it is quite possible it has just been duff since new..
As mentioned above.. When I undo the feed pipe from the back of the filler I get absolutely nothing leaking out.. So to my mind that must mean no one way valve in the filler..
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
You would only get gas leaking - not liquid. As the pipe warms up after filling the liquid would expand and eventually turn into gas as it does so. Most of it ending up in the tank. By the time you have undone the fitting the tiny amount of gas in the pipe will have seeped out. If you had a working one-way valve that is.
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
OK.. so just to reiterate . clarify.. I get nothing out of the pipe at all,, nadda, diddly squat, ziltch.. sod all.
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
True, there is a NRV on the fill point but it may not be seating. I had one which would discharge into the other cylinder that way. The symptom is that if the faulty one is used as a reserve, auto changeover does not occur and you can draw gas from the second cylinder, even if it’s switched off. Then, when you fill up before switching to reserve, you may find you can put more gas back in than the master can hold. If the cylinder’s less than 15yrs old, GasLow will refurbish it under warranty.
Release the fill pipe in the open air. Any trapped gas should stop coming after a while, unless an NRV is faulty. You’d need to disconnect the pipe completely to tell which side the gas is leaking from.
Sidney
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Joe
Yes I know a lot of time has passed but I alwys think it's nice to close a thread with what happened next (just in case anyone needs to know for future reference).
It went "fft"! Not "PHUFFPHT" like when you take the filler off, just fft. (y)
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
No you don't there is a valve in the cylinder to stoop that happening plus the shut off one. disconnect it and a bit in the line is spilled that is it. If you don't believe me then just crack the nut and see what happens, I had a filled, and a new cylinder in my car going to pick up my new van and it does not leak or my car would be filled PDQ. I set them up as a normal cylinder until I got to a rally I was going to and then fitted the whole lot on the site along with another van which I arranged to meet there to do the same. If there was no valve then the cylinder WOULD fill right up and not shut off at 80% which is how they work.
