I've just brought me a camper:)) (1 Viewer)
Apr 28, 2013
3,682
80,730
Alentejo,Portugal
Hymer A Class
Since the '80,s
Hi Matt and a big welcome from :france: you will get loads of help on here and be the best few quid you will spend!!
Not just camper stuff but a chill out read,laughs and much more:cheers:
Oct 15, 2012
10,187
57,395
Market Harborough
C Class Laika Ecovip 7R
Hi and welcome to FUN, it will be the best £10.00 you have ever spend you will get it back in advise alone, in fact you seem to have already received more than £10.00 worth of advise already. (y)
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
Hi and welcome. .
first rule of motorhoming, ... the journey is the holiday.. not how fast you can get there..
but yes.. it should go a tad quicker..
Except when you're late for the ferry...
I now need...^^^
Nobody worries about typos here.. but you do need to pay the tenner if you want to keep posting. I saved over £100 my first week as a member by getting some very useful advice on European breakdown cover.
matt stevens
matt stevens
13
4
Sutton Coldfield
Fiat Ducato Hymer 1991
Newbie
Hello again people. Thankyou for the warm welcome.
Ok so I brought it tuesday, and had plans to get it fully serviced inc cambelt and looked over, towbar fitted then go racing in Dorset the weekend. That didn't happen...
The towbar I'm buying the and having it fitted by the mechanic doing the service. So I thought I'd work my way around how things work. I can't get any water to run, no taps, no flush and I can't get the fridge on either.. Has it anything to do with I wasn't plugged into power externally. So I was using an onboard battery. I Really have no idea. :-( but I'm getting there:)
mjltigger
1,619
2,672
Trowbridge
First things first, I don't know your can but somewhere there will be a control panel. There is likely to be a battery meter on here and some buttons .. German you say.. hmm.. dunno.. but one of these buttons will make the meter dance. Does it go all the way to the green?
matt stevens
matt stevens
13
4
Sutton Coldfield
Newbie
There is a control panel, and it says bat1 and bat2. With the inverter switched on, they both go pretty much all the way up to the green. With the inverter off only the one goes up. So is the inverter running off the van battery?
mjltigger
1,619
2,672
Trowbridge
I imagine it is. One bat will likely be your hab battery (leisure battery) and the other your engine starting battery. You use that switch to choose which battery to take power from. You only want to use the engine battery in an emergency. Someone who knows your van may be able to tell you which is which otherwise it's time to get the multimeter out.
Another switch on there will turn your water pump On. That's a good start because if you've found the gas then you can have a cuppa while you work the rest out.
matt stevens
matt stevens
13
4
Sutton Coldfield
Newbie
Well the guy who owned the van before just messaged back. He said if it's all on from the control panel the pump should work. He said give the pump a good shake inside the water barrel or blow air down one of the taps to apply back pressure. Also the heater, you can hear the igniter clicking but it's not firing up. Anyone live local lol???
