I've frozen husbands navman s80-help!!
Discussion in 'GPS Navigation' started by cornishgail, Apr 5, 2010.
  1. cornishgail
    cornishgail Read Only Funster
    Dec 17, 2009
    22
    sunny[sometimes] Cornwall
    Navman s80:Eeek:
    Was downloading the caravan club cl sites from the club site and I must have done something wrong. Got this warning on screen and it has frozen the system
    fatal applications error appeared.
    programme miobtcore.exe
    exception 0XC000005
    address 01DA0BD0
    This is his pride and joy ...and I haven't told hi.
    What can I do please??
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,368
    18,055
    YO11 2BD
    halfords are still open.....:Rofl1::Rofl1:
    does it have a hidden reset button, usually needs a fine point...needle etc to press it.
    resets to factory defaults....otherwise, sorry cant help.
  3. Autoquest
    Autoquest Read Only Funster
    Oct 13, 2008
    391
    36
    Small EU backwater
    Put it back in the box, put it back where you found it, plead that it had nothing whatsover to do with you and never play with his toys again...:RollEyes:
  4. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,394
    1,479
    Suffolk
    I know NOTHING about sat-nav----------------------but I have found that anything with a computer in it that goes 'brain dead' will come back to life if the battery is removed for a few minutes---------you may loose some stored info ??????? but thats what I would do.
    Good luck
    Nigel
  5. motorhomer
    motorhomer Read Only Funster
    May 17, 2008
    578
    317
    South Shropshire
    All good suggestions!
    I assume this happened whilst connected to the computer. Have you tried disconnecting it and then switching it off and on again?
    If it was disconnected then try connecting it and then disconnecting it.
    Don't know whether or not that paricualr device has a reset button, if not holding the on button for some seconds may have the same effect.
    Good luck!
  6. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    9,064
    14,369
    Norfolk
    Have you considered leaving ??? :BigGrin:
  7. lebesset
    lebesset Read Only Funster
    May 31, 2009
    760
    may be like more recent tom tom's , you just press the start button but keep holding it down until it resets
  8. cornishgail
    Dec 17, 2009
    22
    A million thanks!!
    You are totally brilliant!! It worked holding the button down for several seconds - now I won't have to own up - or leave home!!
    regards
    Gail :Doh:
