Its raining & my roof is leaking? (1 Viewer)
asinboat43
13
anywhere & everywhere
RV
9 years
Hi everyone,
Looking for advice with how to stop it raining?? or fix my RV roof, or both, which has now given us an extra 2 showers up front right over the driving cab....anybody got the ultimate in sealants or mastics...what to use?
Our RV is 14 years old a Safari Serengeti and we love her to bits, don't want to see her turn into a submarine :cry::whatthe:
cheers asinboat
:thumb:
zaskar
1,159
371
UK
5th Wheel
Have you got a fibreglass or EPDM rubber roof ?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Neither by the sound of it:whatthe:
But it does make a huge difference:thumb:
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
I have just used Everflex Weathermate Sealant made by Everbuild around my windows on our fifth wheel, this can be applied even when the surface is wet. Wasn't sure if you could use it on rubber roofs, so I just rang their technical department and they said they wouldn't recommend it on a rubber roof, but to use their other product called Puraflex 40 which I have used in the past and it bonds as well as seals.
However, on looking at the spec. on line, we read that it can't be used on wet surfaces.
Food for thought.
Nigel
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
Hi everyone,
cheers asinboat
:thumb:
If you give Stateside or Star Spangled Spanner a call you will get some really well informed advice.
Jim
:Smile:
scotjimland
2,322
10,021
A Woosh bang
Sounds like the joint between the fiberglass front cap and the rubber roof, a common place to leak..
if so you need:
EPDM Rubber Roof Sealant
Dicor special lap sealant for use on rubber roofs, specially formulated for sealing vents screw heads air con boxes etc, 10.3 oz tube £8.50
call linda for advice and fast service
Link Removed
In the meantime, try to raise the front end of the RV so that the rain runs backwards on the roof and not into the joint,
jim
asinboat43
asinboat43
13
RV
9 years
if so you need:
Link Removed
jim
thanks for that, will do the easy bit and re-jack the front, and when it stops raining will be back on that roof,
many thanks
from a novice RV-er
cheers asinboat :Doh:
asinboat43
asinboat43
13
RV
9 years
if so you need:
Link Removed
jim
thanks Jim,
will try tomorrow
cheers asinboat:thumb:
scotjimland
2,322
10,021
A Woosh bang
many thanks
from a novice RV-er
hi
we were all novices at one point.. I had leak in the same place so I was fairly sure.. mine used to leak when the RV was low at the front.. wait until it's dry and warm to do a re seal.. no point in trying to do while it's wet..
if push comes to shove, scrape out any old dried out sealer then use a warm air gun or hair drier to dry out the joint before re sealing, you can always re do next summer .. and that would be a good time to check all the seals and re paint the roof with Plas T Cote ..also from Linda :thumb:
jim
American Dream
156
Lincoln
Isoflex is a liquid rubber sealant/paint available from B&Q at a really good price for 5 litres if it is an emergency.
It Is BLACK but can always be overpainted afterwards with a white epdm "paint"
Brill if you need a quick and lasting repair while waiting for snail mail or a courier.
