It would seem dartford tunnel closed. Evening standard (1 Viewer)
Oct 1, 2007
7,064
13,964
Kirby cross further from londin
Between Motor homes
since 08
The twin boars /tunnels are closed bridge is open
Safety fears seemingly
Dartford Crossing tunnels closed over safety fears sparking M25 chaos
Evening Standard
Drivers have tonight been urged to avoid the Dartford Crossing after both tunnels were shut for safety reasons. Read the full story
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
maybe one of the cameras has gone off. There seems to be a very response to CLOSE the tunnel when some incident occurs but BOTH.
Need to fin out more but know nothing yet. There needs a way to turn the traffic around through to the other direction to save these huge holdups when people are trapped for hours because of the barriers not being openable because it is illegal to do U Turns on a Motorway , for obvious reason normally but under controlled circumstances?????
tofo
Oct 1, 2007
7,064
13,964
Between Motor homes
since 08
In the wrong truck its a long trip right round the m25
consider the LEZ and whatever route you need to take
Not sure if £100 a day will be imposed because of tunnel closure
It is I believe a 106 miles going round bridge back to tunnel
It could end up cost of diesel v charge
Jun 23, 2013
251
131
Hurworth-on-Tees, Darlington, UK
Knaus Sun Ti 650 MEG
Since July 2013 but been camping for 25+ years
We do the software that works the signs and signals for the Dartford Crossing. It all works in the factory! I'm sure I'll find out tomorrow what the problem was !
May 29, 2013
2,589
19,161
Tyneside
Chausson best of Flash 10
Several years now
We came thro tunnel Sunday lunch time, relatively quiet for traffic, it was obviously flowing too well, so they had to do something about that!!
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
5 years, feel free to ask me about the Carado!!
Something in The Dartford tunnel took a chunk out of my rear wheel. :(
Jan 28, 2008
10,111
18,365
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
it was shut yesterday afternoon when we c ame home from margate 1a to 31 closed on the warning signs
the section through the tunnels and bridge is actually not motorway ive won some spectacular arguments as to which motorway circles london at quiz nights the answer is of course none
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
No the LEZ always applies, I got caught out going down the A13 when this happened the other way over the bridge, Police told me to go down the A13 and across the Blackwall tunnel, which I did. I should have remnoved my number plates first it seems.
The official diversion is 121 miles back to the A2 there are two signs on the M25 stating the diversion route around the north side.
It cost £1000 penalty for taking a 3860kg motorhome as the Euro 3 does not apply, it has to be a higher rating. They consider you the same as a 40tonner.
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
I noticed suprisingly in the slightly disorganised Netherlands they explained in English the LEZ requirements before you went in!!
Aug 18, 2014
23,739
133,173
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Even when working "normally" it is useless. All removing the toll booths has done is shorten the queue by 2 miles. The need for "escorted" loads through the tunnels is one of the main reasons for the constant queues.Utter shambles & will remain so until the new crossing is completed downstream in about 2027. I'll hopefully be dead long before that.
Aug 18, 2014
23,739
133,173
Lorca,Murcia,Spain
Transit PVC
that is so that they can continue charging to use it & so that local traffic, including motorway prohibited stuff including tractors etc ; can use it
tofo
Oct 1, 2007
7,064
13,964
Between Motor homes
since 08
I lived in Thurrock two years back whatever happens at that junction
M25 or a13 the whole place was at a standstill
We came back from the isle of white few years back
Tunnel was shut we had to do the full circuit
2 hrs and a nightmare 5 in the evening and needing to get home for night shift starting 20.00 hrs o'clock
Just glad I moved away just far enough to visit son DIL and granddaughters in 75 minutes ish
Jul 23, 2013
381
221
Scotland
knaus van ti 600mg
Getting There since 2013
Is the Dartford tunnel back to normal? We're heading back to the UK tomorrow morning hoping to head straight up the A1 is there likely to be big delays? Thanks :)
