Isolating Leisure Batteries for Long Term Storage
Discussion in 'Tech/Mech General' started by Falcon 269, Aug 23, 2014.
  1. Falcon 269
    Falcon 269 Funster
    Jul 11, 2013
    162
    401
    Spain
    Our Adria sits in secure offsite storage with no EHU for many weeks between runs and it will be that way for until next year, unfortunately.
    The master control panel supposedly turns off all electrical demands on the leisure batteries but I wonder if I should be physically disconnecting them as well?
    If that's the case, rather than mess with the terminals, would it be OK to fit battery isolation switches on the pos & neg cables to achieve the same effect?
    Thanks in advance. :)
  2. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,960
    2,785
    Kendal, Cumbria
    You should not need to isolate them but if you choose to do so one isolation switch on the +ve lead to the MH electrics is enough. However if "many weeks" = more than 6 your batteries will have a very short life. A much better option if they are left longer than a month is to bring them away with you & connect them to a modern trickle charger.
    • Like Like x 2
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,362
    9,809
    a quick way to kill batteries is to leave them without maintenance charge for months on end. an isolator is only ok for short terms,
    • Like Like x 2
  4. Falcon 269
    Falcon 269 Funster
    Jul 11, 2013
    162
    401
    Spain
    Makes sense, thank you both.
    I think I might be investing in some quick release terminal clamps, or perhaps bring the girl out of storage more frequently for some time on EHU at home.
  5. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,438
    7,725
    Why not just pull out the fuse or 2 mins with a spanner and the terminals are off completely.. Cant see any point in spending time and money doing a longer job for something you plan to do just now and again..
  6. funflair
    funflair Funster Life Member
    Dec 11, 2013
    4,847
    5,124
    Guisborough
    It might depend where the batteries are located. I believe some are well hidden under seats and floors etc.
  7. tonka
    Jul 2, 2008
    5,438
    7,725
    Yes,.. agree on that. Just thought as the OP was talking about fitting quick release terminals he is doing half the job to start with.. :)
    And not going back to it till 2015 it's not a great hardship...
    Sure a solution will be found.....
