Is this Tv suitable for my camper
Discussion in 'TV & Satellite' started by vectian, Mar 1, 2015.
  1. vectian
    vectian Funster
    Sep 21, 2013
    152
    132
    Isle of Wight
    My daughter has just given me a Bush 19" HD ready LED TV model No L319LED power consumption 42w, which is now redundant as my granddaughter has a big posh Smart TV.
    Its powered through a transformer and has a 12volt input at the back of the unit.
    As the present Tv system is an old monitor with a Freeview box, and hasn't the right resolution for my lappy to plug into I wish to use this in my camper.
    If I do use this will it drain my leisure batteries as it is meant to be used on the mains.
  2. colinw
    colinw Read Only Funster
    Feb 1, 2015
    525
    306
    Bolton , Lancs.
    How much energy does the monitor consume ? . you should just require a 12volt power cord and away you go .
  3. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,095
    6,090
    West Sussex
    Should be OK it will draw about 3.5 amps quite high compared to some LED TV's ( our 19" Cello takes 1.5 amp) no more than the slightly older LCD T V's, also that will be max power, you will probably find in use it will take less than 2.5 amps.
  4. laneside
    laneside Funster
    Aug 14, 2009
    3,566
    5,568
    Oradour sur Vayres
    Be careful plugging into the 12 volt van plug as some telescope object to the possible14 volts. This is easily overcome with a voltage regulator off good old Ebay
    Flipping predictive text------ TELEVISIONS
  5. vectian
    vectian Funster
    Sep 21, 2013
    152
    132
    Isle of Wight
    Thanks all.
    Now just go and get a wall mount for it and we're off then
  6. Spade
    Spade Funster
    Aug 5, 2014
    105
    25
    Hi.would a voltage regulator allow the Tv to be used while the van is driving And the batteries being charged.
    Also any chance of a link.
    On my phone and eBay search gives me thousands of matches.
  7. laneside
    laneside Funster
    Aug 14, 2009
    3,566
    5,568
    Oradour sur Vayres
    Yes is the answer assuming that is what you want to do. Search 12 volt stabilizer on eBay I agree there are lots at £20 plus, the only thing you need to be concerned about is if the jack plug is compatible With your television
  8. Spade
    Spade Funster
    Aug 5, 2014
    105
    25
    Thanks for the reply.
    It would be handy to put on a dvd for the kids while travelling,but I have read that changes in voltage coming from the batteries can vary and damage a tv.
    The question is ,how do you find out without doing damage.
    My power lead has a 4 pin din connection but thank you for putting me on the right track.
  9. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,620
    2,191
    Rutland
    image.jpg We just use the tv from my eldest's bedroom via a cheap inverter ..Didn't see the point in buying another 12 v tv after the last one died. We use it on the move via the 12 v outlet on the dash.
    I know people will say its a waste of battery power converting to 240 v but with 2 batteries and solar pannels I'm not worried .I use the inverter when wilding and no probs as yet.The inverter also comes in handy using low power items that aren't 12 v compatible.
