Is this the strangest waste water question yet? (1 Viewer)
Mags52
1,433
1,731
Melrose Scottish Borders
Hymer B774
Since 2010
Today when we emptied our waste water into a bucket a piece of paper came out about the size of a large parcel label. There is no way this could get down any of our drains inside the van. After this the waste water was thick and gloopy for a while. We put several watering cans down all the plug holes and now the waste looks normal. Weird eh?
Riverbankannie
10,529
61,520
Bristol
IH 630 RL PVC
Gosh, how long have you been using the system? Was the paper intact, if so cannot have been in there very long. Could someone have shoved it up the pipe from outside?
Mags52
Mags52
1,433
1,731
Hymer B774
Since 2010
We've had the van for 18 months. The paper was pretty ragged but there is a little boy on the pitch next door. Mmmmm ... could be
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Some (not all) waste tanks have a cover, which is sited on the top, Allowing access for Screwed fittings to be attached after which they are sealed up, The label would likely be a "Stock" label and has eventually detached, partly blocked the drain, and when it eventually got to the exit has the effect of removing the dam and allowing the Crud behind it to come free?
Mags52
Mags52
1,433
1,731
Hymer B774
Since 2010
That makes a lot of sense. Maybe our waste water won't smell so bad now.
Reactions: CWH
Oct 7, 2013
5,894
36,906
South Wales
Swift Escape Compact
Since 1988
@Mags52
Are you parked anywhere near Sherlock or Morse?
Sounds like a job for them!:whistle:
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
....We put several watering cans down all the plug holes and now the waste looks normal. Weird eh?
Just you wait until the all those watering cans make their way through your system.... You thought the piece of paper was bad ! :getmecoat:
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Was it in a bottle?? You might have a shipwrecked mariner marooned in your grey water tank. (y)
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
The distinctive smell doesn't occur if you leave the grey waste tap open...
:reel:
Mags52
Mags52
1,433
1,731
Hymer B774
Since 2010
Sounds feasible, I cant see how it could have come from the tank...
We've got a wide bore exit (no rude analogies please ;) )with a right angle bend in it. I guess someone could have fed a bit of paper up there - why they would do that is anyone's guess. It's the thin wallpaper paste consistency of the water that followed it out that confused me. Seriously strange.
Jan 27, 2009
872
3,359
Leyland Lancs
since 2001
Was it definitely paper ?
Over a period of time/use if ALL liquid waste is poured down the sinks, then a brownish deposit will form on the bottom of the waste tank. This deposit will form into a thin skin, and can exit the tank looking like thin wet pieces of paper.
Minxy
32,646
66,526
E Yorks
Carthago Compactline
I'd say it was a label originally attached to the underside of the inspection cap which has come unstuck and found it's way out through the pipes eventually ...
43,323
49,427
So, little tarquin knew to open the waste valve, with the possibility of getting soaked in stinking grey water, then using some kind of probe to push the label right inside the pipe... ?
It's a stock/part number label which became detached or was accidentally or intentionally dropped in the tank by the fitter on installation
Minxy
32,646
66,526
E Yorks
... just a thought ... you know how when a dog consumes a piece of tissue you hope it comes out the other end 'wrapping' up the rest of the contents ... you haven't been trying that have you ....???? :LOL:
