Is this photo correct (1 Viewer)
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Hi, We found the MH very draughty so I bought these winter vents from ebay but now notice apart from the wrong colour they are too short so then I thought that perhaps they are meant to fit on top of existing covers. It looks ok but the bottom keeps popping out.
Is this how they go or are they totally wrong ones?
Thank you
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
The vents look correct as there is supposed to be a gap for air circulation (as I understand it) . But if your chausson has a built in has step like ours.. The vents in that step let in a positive gale.. Maybe worth checking if you have the step.
Armytwowheels
6,473
14,871
Market Harborough
Carthago S Plus - Iveco
Since 2011
I think, but not 100% sure! that they are supposed to have the gap at the bottom, as air still needs to circulate through to make the fridge work properly. But you shouldn't need fridge vents on at this time of year.
Maybe the draught is coming in the van because the fridge isn't sitting properly in it's housing. You need that air passing over the back of your fridge and as the weather gets warmer the more air the better.
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
I don't know what type of rooflights that you have, but ours had no seals fitted and let in a horrendous draught.
The MH was constantly cold.
Have a look on here Broken Link Removed
Hope this is helpful. :thumb:
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
The winter covers you have may be fine although you shouldn't need them once the temperature outside is above approx 8deg.
However, if you are experiencing a draught inside the m/h which is coming around the fridge then the fridge wants sealing as you may be drawing in carbon monoxide when fridge is on lpg.
I hope you have a CO detector fitted .... if not I would reccommend getting one urgently.
irnbru
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Wish we had some of the sunshine England is having. Its only 6c here and feels more like 2c:Sad:
Puddleduck
12,385
43,988
Scottish Borders
Without at present
On and off for many years.
Same here in The Scottish Borders and thick fog / low cloud. <bbbbbrrrrrrr>
I can't even see the garden though the window.
Armytwowheels
6,473
14,871
Market Harborough
Since 2011
Oh dear, that's not good, maybe you do need the fridge covers on then. But like others have said, not to cut down drafts in the van.
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Before you panic too much remember you can remove the external louvred panel top and bottom and look inside. The ventilation space at the rear of the fridge should be enclosed (and all joints in wooden panels are normally sealed with silicon).
If it all looks pretty than the draught is coming from somewhere else. Which is normally the case. A few tea light candles will show up draughts quite well (although it may be better if you're not driving at the time) :thumb:
MattR
4,104
38,844
Beds
Panel van
Years
We have two vents on the side of our La Strader (Sprinter body). The draught is [STRIKE]pretty[/STRIKE] bad. One vent appears to have the exhaust from the fridge, the other appears to be venting the leisure battery area. I'm buying a new LB (which won't vent gasses). I'm guessing that I can block the vent for the LB area (is that likely to cause a problem) but is there anything that I can do for the fridge vent?
irnbru
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
We have 2 vents one above the other at the fridge and one to the side where the grill is. Draught seems to be coming from the vent opening above the grill door, also when you open the cupboard door below the grill.
MHVirgins
3,889
3,158
South of Scotland
March 2011
We've just spent two fantastic sunny weeks at Roslin, the weather was cold, but we had brilliant sunshine every day until Friday and Saturday just there. Our son and his wife work in Edinburgh and they were saying about the weather over the last couple of days, bitterly cold and thick fog......so think we were lucky with our two weeks at Roslin.:sin:
Yesterday down here in D & G was sunny and warm all day and today was lovely as well:thumb:
Great weather for getting all the washing dried outside.
Having hotmail problems otherwise I would post a couple of photos on here.
Margaret
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
Thank you
Ours have 2 locks that you turn with a coin at the bottom to,keep them in place ::bigsmile:
Mike
9,543
32,065
sleights
c class
We found the biggest draught was the vents for the grill/oven same on our new one thinking of blocking the vent off and putting a label on the gas shut off valve so we dont forget to remove it before use
David
3,872
5,270
The City of Henlow
Adria Supreme
Since 1980
It is the right vent but the wrong colour. I could be wrong but I think that most marques will sell covers in their own colours. I know that Dethleffs do, and theirs are much cheaper than Dometic to buy.
Alan
