Is this a common occurance?
Discussion in 'The Beginner' started by Letsgetaway, Sep 1, 2012.
  1. Letsgetaway
    Letsgetaway Read Only Funster
    Jun 24, 2012
    30
    4
    Cornwall
    Having got back home after being out and about we noticed water on the table, floor and seat which had come through the roof light :Sad: - granted it was absolutely lashing down. We took it back to the dealer and they told us the water/rain gets blown in and is a common problem with all types of vans :Confused:
    They did drop the bottom frame for me to have a look and there was no sign of water penetration.
    Do any of you get the same thing happening? If it's that's common I guess I'll be hearing from all of you:Rofl1::Rofl1:
    Many thanks
    Rachel
  2. Chris
    Chris Funster Life Member
    May 5, 2010
    16,728
    36,812
    kent
    It doesn't happen with our van.
  3. Carol
    Carol Funster Life Member
    Oct 2, 2007
    10,719
    15,512
    North Wales.
    Never had that problem.
  4. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,638
    7,712
    england
    no its not common,never had it in any of the van's i have owned:Doh:
  5. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,617
    5,689
    Yr Wyddgrug
    Nor mine.
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,103
    17,777
    YO11 2BD
    depends on the type of roof light fitted.
    some have slight but permenant ventilation even when closed but the rain would need to be horizontal and in a force 9 gale to find its way in.
    stick a free running hose pipe on the roof for while and see if it still leaks then..if it does, you have a failed seal
    • Like it Like it x 1
  7. Letsgetaway
    Jun 24, 2012
    30
    4
    Cornwall
    Thanks for the replies so far.
    It is the type that's like a sun roof with a windy handle (and permenant ventilation) rather than a small sky light.
    Off to try the running hose pipe on now.
    Thanks again and keep them coming :Smile:
  8. Pigwam
    Pigwam Read Only Funster
    Jun 15, 2012
    45
    8
    Chester
    Sort of defeats the object, if its meant to let water in then it will have a warning in the handbook.
    But somehow i doubt its made to let water in - email the manufacturer - then you will know for sure.
  9. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    We have one of those (Heki 3) and never any problems with water penetration when it's closed.
  10. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,624
    1,471
    West Midlands
    No ours doesn't either - even with full force from hosepipe or even pressure washer
    Wyn
  11. Heyupluv
    Heyupluv Read Only Funster
    Oct 7, 2008
    3,860
    1,583
    France,
    I don't how old your RAPIDO motorhome is....ours is year 2011...and we have what you call the windy handle type......now our RAPIDO dealer made a point of telling us, when you wind the roof light down even though it looks closed keep winding (not with great excessive force to break it) until you come a stop....then and only if needed just wind it back in the opposite direction about a 1/4 turn so its fit into the recess....he said this is to seal the roof light...its just a thought you may not have been completely closed.
    Now to answer your question... NO... we do not get any water in when the roof light is closed.
    Mel
  12. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,984
    2,780
    Englishman in Mid Wales
    Got one on my motorhome and two on the caravan and no water has ever come in unless they are open:thumb:
  13. Letsgetaway
    Jun 24, 2012
    30
    4
    Cornwall
    Thanks for all your replies. Yep, it's a leaky seal, now back dealers to sort:thumb:
  14. Chris
    May 5, 2010
    16,728
    36,812
    kent
    I would have a go at them too for feeding you bullsh*t.
  15. pappajohn
    Aug 26, 2007
    30,103
    17,777
    YO11 2BD
    easy enough to fix providing it hasnt been leaking for a long time and rotted the wooden batten frame.
  16. hilldweller
    Dec 5, 2008
    27,551
    26,638
    Macclesfield
    Yes.
    It needs a lot of wind and rain in a certain direction and then it can blow a bit of water over the sill. Only happened twice in 5 years.
  17. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,506
    3,720
    Lost in La Mancha, Spain
    Well we sat through a 3 hour thunder storm the other night and is was lashing it down and not one drop of rain so I would be heading back to the dealer and getting it fixed. Bloody cheek I think to tell you the bullS1it.......
    Don
  18. spongy
    spongy Funster
    Jul 29, 2009
    278
    95
    hampshire
    we had it happen in a thunderstorm once, mind you the skylight was open at the time.
    spongy
