Is the Motorhome OK
Discussion in 'Motorhome Chat' started by GregM, Feb 11, 2010.
  1. GregM
    GregM Read Only Funster
    Nov 2, 2009
    255
    Nottinghamshire
    We're off to sunny Colchester this Saturday for a few days, and as newbies this is the first time we've been out in cold weather.
    Is there anything we must or should have done before going away?
    The fresh water and hot water tanks are under the habitation seating. The waste tank is under the van, neither the waste tank or the pipes going to it appear to be lagged or anything.
    Obviously when in the motorhome the heater is more than likely going to be on, we are likely to be driving about visiting relatives so the van is likely to be left unattended without heat for just a couple of hours a day so hoping the tanks inside should be OK, but will the heat be enough to stop the waste pipes/tank from freezing overnight?
    Is the Motorhome going to be OK?
    Greg and Tracey
  2. Mikemoss
    Mikemoss Read Only Funster
    Aug 14, 2007
    178
    49
    Corsham, Wilts
    Hi Greg and Tracey
    I think you'll be fine. Will it be possible to leave your water heater on while you're not in the motorhome? If so, that should certainly stop that freezing up. The only other thing I can think of is to leave your waste water tap open so the water goes straight into a bucket (or similar) rather than into the tank.
    The fresh water tank should be fine inside the van.
    Hope you have a great time away!
  3. GregM
    Nov 2, 2009
    255
    Nottinghamshire
    Yes mike, normally we only turn the water heater off at night but this time will leave it on 24/7.
    Thanks for the waste suggestion, I had wondered if that would be better.
  4. ourcampersbeentrashed
    ourcampersbeentrashed Funster
    Apr 19, 2008
    7,652
    4,284
    East London
    Just make sure to empty all the water tanks and taps when you come back - dont leave them to freeze up xxxxxx
    am sure you will have a great time
  5. finby
    finby Read Only Funster
    Oct 3, 2007
    236
    norfolk
    You should be fine - weve been away in winter and not had any problems. Good advice to leave the water heater on as much as poss and drain down when back home again.
    Martin
  6. scotjimland
    Jul 25, 2007
    28,935
    25,616
    Hi Greg
    we live in Colchester, have you planned where you are staying yet ?
    There is a great CL not far from the town center, we stayed there while we were full time and are friendly with the owners.. http://www.thelodgecl.co.uk/
    hope you have a great week end, if you need any other advice or help re Colchester let me know
  7. GregM
    Nov 2, 2009
    255
    Nottinghamshire
    Thanks Jim
    That is where we are staying:)
    Last year our first trip in the van was to Colchester and we stayed on a CL in Ardliegh but it is closed this time of year. We found 'The Lodge' and that actually suits us better as my parents live in the town, near what I call the Williams and Griffins car park (is it still W&G).
  8. GregM
    Nov 2, 2009
    255
    Nottinghamshire
    Jim
    Just thought thanks for the recommendation by the way, although we had already booked it's good to have someone recommend a site.
  9. froghopper
    froghopper Read Only Funster
    Nov 29, 2009
    413
    176
    winchester
    out in cold
    have a great time, dont forget to drain toilet water,, you should be o k for warmth this weekend,,, after all it is valentines day :BigGrin::BigGrin::BigGrin::BigGrin::thumb:
  10. scotjimland
    Jul 25, 2007
    28,935
    25,616
    It's still W&G ...
    We live near the Priory about 10min walk from town center ..
    I was there last week visiting another couple with an RV, ended up helping them extract the RV from the soft ground.. :Doh: .. now left for France..
    Take care on the grass and stay away from the fence on the left bordering the country club..
  11. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,815
    13,725
    Norfolk
    We have just had a couple of nights in Colchester. To get a hardstanding we stayed at Colchester Camping, boy thats expensive, £28 a night for RV and 2 adults. Good quality pitches though.
  12. geoff1947
    geoff1947 Read Only Funster
    May 20, 2008
    999
    92
    Plymouth
    cold bed
    Nothing to do with the water & pipes etc but if you are staying in the van overnight wear a woolen hat in bed,. not very sexy on Valentines weekend"!!!! but you will lose a lot of heat from an uncovered head if the weather is cold:Rofl1:
  13. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,952
    17,634
    YO11 2BD
    following on from mikemoss suggestion re: leave waste tap open, if it looks like feezing then check the drain valve from time to time.....a dripping tap will freeze quicker than a closed one and as you move around the van it will drip a bit.
    if it starts to freeze then a T towel soaked in boiling water and placed over the valve will thaw it.:thumb:
  14. barryd
    barryd Read Only Funster
    Feb 10, 2009
    1,144
    103
    Yorkshire Dales
    IT will be fine because your using it and unless you like sitting around in sub zero temps then nothing should freeze. We were away for a month at Christmas in our Kontiki and the only thing that froze occasionally was the kitchen sink drain which for some strange reason Swift decided to run it under the outside of the van to the main grey tank. It only happened a couple of times when it was mega cold. -12 one night wild camping in Devon. A bit of warm water soon shifted it.
  15. GregM
    Nov 2, 2009
    255
    Nottinghamshire
    Is the country club what used to be Kingsford Park Hotel?
    I stayed there once years ago as a tugger, good pitches but wouldn't go back because of the price, would rather use the Lorry Park up the road:Rofl1:.
    I suppose it's OK if you've just come accross from Harwich or somewhere like that.
  16. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,815
    13,725
    Norfolk
    Think I'm getting soft, its cold so prefer hook up as well as hard standing in winter .
  17. scotjimland
    Jul 25, 2007
    28,935
    25,616
    I really don't know, but more than likely, it's called Clarice House Health Club
  18. davejen
    davejen Funster
    Aug 21, 2008
    1,260
    717
    Kirkpatrick Fleming Dumfries
    Leave all the taps OPEN too- this will stop any water freezing in them and buggering the seals up. Just be careful when you fill up after and switch the pump on!
    Cheers, Dave:thumb:
  19. GregM
    Nov 2, 2009
    255
    Nottinghamshire
    Thanks for all the advise, it's greatly appreciated.
    THere is an open invite for anyone in the area to pop in for a cuppa but we do not have plans while we're there so do not know when we will be on/off site.
